ok.. heres the story... 99 gp gt 170,000 miles just did a head gasket.. while i was in there i did all the intake gaskets, had the heads and lim prof. cleaned.. new plugs and wires, still wasnt running right.. so i did the map sensor too (coolant actually completely separated the sensor) and i did the pcv valve.. that solved the problem.. but now i have fluctuation in my rpms again, not as drastic as before but by a couple hundred rpms at idle. and when it has been running for a while then there is a smell of burning coolant when i have the heater on. and the low coolant light occasionally comes on but goes off after a max of like 2 minutes.. im probably gonna get a million possibilities for what is wrong with it, but hey its worth a shot
