Hello everyone. I am new to the forums but plan on becoming more and more active, I've found this forum very helpful in the past. Anyways, to the point. I just swapped a 3800 Series 2 NA from a 99 Lesabre into my grand prix, after my old engine spun a rod bearing. After we got it running, I noticed the Oil pressure light would not turn off. I didn't hear anything in the bottom end but the lifters in the top end were rattling away. I did switch the oil filter adapter due to the engine mount, so the regular grand prix filter adapter is on the block. I read somewhere that I could prime the pump (its been sitting at the wreckers for who knows how long) by adding a few extra quarts and running it for a few moments. I did that, and noticed no change. So i pulled off the oil filter and discovered it was dry. I filled the filter and stuck it back on in hopes that would help prime the pump. Fired it back up and ran it, and still ticking away in the top end with the light on. I pulled the filter once again and noticed the filter was empty (so the pump is obviously sucking the oil). I then pulled the filter adapter, but there wasnt a drop of oil in the channel leading to the filter. What could it be? Something in the pick up line or screen? how do I solve this without pulling the pan? ( I dont wanna lift the engine again...) =[
any help would be much appreciated. It is also throwing a code for a high value reading from the MAP sensor, if that would possibly relate in any way to this issue. Thanks in advance!
