Thread: Msd coil packs advice
Page 1 of 3 123 LastLast
Results 1 to 20 of 49
  1. #1 Msd coil packs advice
    Calgary
    so i am buying msd coilpacks for my car and wonder if its a good idea??
    as well as the K&N Intake kit
    pros? cons?? THANKS!
  2. #2 Re: Msd coil packs advice
    No...neither are useful OR worth the money.
    Stock coils are way better than MSD's.
    Make your own intake...or, read this thread....
    http://www.grandprixforums.net/safel...car-17482.html
  3. #3 Re: Msd coil packs advice
    Dec 2008
    Lawndale, CA
    Stick with the stock coils. If you can find a K&N for cheap then get it. I picked up mine used from another member.
  4. #4 Re: Msd coil packs advice
    SE Level Member Robby Avery's Avatar
    Deep South Georgia
    I've read the link you posted and I was curious. When you DIY the CAI do you leave the ECM in the the stock air box and just put the cone filter on the rubber boot off the TB or how would you go about it on a N/A engine.
    Girlfriend's ride: 03 Summit White Grand Prix GT 180* T-stat, Autolites, Bosch wires, Custom CAI
    My Rides: 2006 LBZ CCSB LT3 Duramax Diesel Puller/DD
    2002 LB7 Duramax Diesel CCSB LT3 to many mods to list! Work Truck/DD
  5. #5 Re: Msd coil packs advice
    Calgary
    well im pretty sure my one of my coil packs is ****ed so im preplacing all of them and doing HIDs and intake while im at it...
  6. #6 Re: Msd coil packs advice
    North Jersey
    I was planning on doing the same if mine go, cause i have a friend w/ a 3800 firebird whose coils went and he got the MSD's and got more mid-range power, just figured it'd be the same for me?
  7. #7 Re: Msd coil packs advice
    LOL mid range power?
    No.
    Stock coils have more power output than MSD's. Proven. You want your car to run better? Get Autolite 606 spark plugs and get better WIRES, like MSD's or PRJ's. Stock coils are used on most of the fastest WBodys around...why? Because they are proven to not fail...just go grab a new set from Autozone OR... Morad Parts Company - 3800 Motors, Transaxles, & Stock Parts
  8. #8 Re: Msd coil packs advice
    Florida
    IF you really want to hear the truth..
    I got MSD coils as a gift, and they ****ing suck ass. All 3 have been replaced, since they were all manufacturing defects.
    One literally split between the terminals, and was sparking all over the place.
    The other two, had the contacts break off...
    They add no power. If you want yours red, get some and spray them red.
    They are a waste of money, and for an intake, dont waste your money, make your own.
    Also, listen to these people telling you advice, most have been through a motor, or 3....
    and they know what works/doesnt.
    Your $350 dollars would be much better spent on other things..
  9. #9 Re: Msd coil packs advice
    North Jersey
    duly noted, thanks again guys
  10. #10 Re: Msd coil packs advice
    SE Level Member TheManiac's Avatar
    Nov 2010
    Mentor, OH
    If you are running an L36, you could try and snag a good set of used L67 coils. Not much difference, but a tad better throttle response.
    The coils used on the L36 are also the same exact part number used on my '94 Grand Am. GM has used those coils a LOT. I have known them to rarely fail. From my experience, 90% of the time people think they fail, they are wrong and it was a different failure. I replaced two coils in many of the 3100/3400 engines I've worked on.
    If you do some searching, I believe somewhere on the Internet I read someone posting a "how to" on resistance checking to see if a coil went bad.
  11. #11 Re: Msd coil packs advice
    Calgary
    thanks guys, did the HIDS, looks amazing and the intake sounds pretty wicked... will see about getting some stock coil packs... i have a random misfire??? and im just trying to find how to fix it so my car tuns top notch... the plugs and wires are all brand new.... any suggestions for that? THANKS!
  12. #12 Re: Msd coil packs advice
    Topeka, KS
    Probably your coil packs. Replace them with stock
  13. #13 Re: Msd coil packs advice
    SE Level Member pur3vil's Avatar
    Bismarck, ND
    I would start with the coils, then ignition module itself. A bad coil will generally be the 2 cylinders that are matched to it. ignition module completely random cylinders.
  14. #14 Re: Msd coil packs advice
    Calgary
    okay thanks will try the replacing of the coils... and hope that helps.... the engine code just comes up with random misfire detected.....
  15. #15 Re: Msd coil packs advice
    Ohio
    so everybody here that bought the msd packs, did you guys buy just the packs?
  16. #16 Re: Msd coil packs advice
    Ohio
    you can zip tie it down on the inner fenderwell where the airbox was, or buy the box/holder tray they make for em. mine is just zip tied down and its fine
  17. #17 Re: Msd coil packs advice
    Deep South Georgia
    Quote Originally Posted by 99PGPGT View Post
    Who makes the AM trays for the ECM? Also was the ecm put there in the stock box for cooling purposes? I worry bout under hood heat being a problem for the delicate module to be heat soaked? With the 180* thermostat I plan on doing like alot you have will the heat still be a problem? If I just go the zip tie route would it be ok if I used exhaust wrap to make sure the ECM doesn't get heat soaked? Sorry for all the Q's just trying to learn as I'm super anal about my rides lol! Sorry if this is off topic but what is the little two wire connector thats in the short rubber elbow between the TB and airbox jw?
  18. #18 Re: Msd coil packs advice
    Ohio
    umm you can get the tray through zzp, wbody store and 3800 performance. or make your own out of sheet metal or your imagination haha but no just zip tieing it wont make it prone to a alot of heat. mines just fine lol now between the airbox and the tb, do you mean the sensor on the tube?
  19. #19 Re: Msd coil packs advice
    Largo, Florida, United States
    Ive been running MSD's for awhile
    honestly i didnt notice a difference between stock & these.
    But they do look nice... thats about it.
    get headers.
  20. #20 Re: Msd coil packs advice
    Deep South Georgia
    Thanks buddy. Yes the sensor on the tube is what I was asking about.
  1. Coil Packs
    By Damojo2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2011, 12:16 PM
  2. coil packs keep going out???
    By chamberlain198437 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2010, 10:33 PM
  3. Coil Packs
    By snodly in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-16-2009, 09:04 PM
  4. coil packs
    By Pontiacman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-27-2009, 09:29 AM
