Thread: Fuel problem
Results 1 to 11 of 11
  1. #1 Fuel problem
    SE Level Member probuilder1's Avatar
    Jul 2008
    VA
    I have a 99 gt with 175000 miles on it and every so often when I go out to start it all it does is just turn over and wont start, if I give it gas it starts but I have to keep my foot on the gas for a while then it will idle. I am either thinking fuel pressure regulator or fuel pump. When I get home from work today im gonna rent a fuel pressure tester. What should the pressure be? If it is the fuel pump can I buy just the pump and screen or do I have to buy the whole assembly? Thanks
  2. #2 Re: Fuel problem
    St. Louis
    Courtesy of 01gpgt01:
    "42 is where you want to be under vaccum and around 48-50ish with no vacuum, and yeah you're supposed to go off the non vacuum numbers."
    As far as the fuel pump goes, I do believe they come w/ a new screen on them, IIRC. Check Rock Auto for prices and descriptions.
    Have you ever changed the fuel filter? What's your tune-up status like?
    Jay
  3. #3 Re: Fuel problem
    Jul 2008
    VA
    I just did a full tune up a couple weeks ago, plugs, wires, pcv, belt, fuel filter, and oil change. Im also gonna clean the maf sensor and throttle body.
  4. #4 Re: Fuel problem
    Feb 2008
    You may need to take the throttle body off and clean it. The IAC valve and passage may be full of carbon and not allowing the car to idle properly when cold.
  5. #5 Re: Fuel problem
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Pull the vacuum line off the Fuel pressure regulator see if gas comes out of the regulator or is in the line. Gas in that line indicates diaphram failure inside the FPR. Can you hear the pump prime? there pretty audible.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  6. #6 Re: Fuel problem
    Jul 2008
    VA
    Ok this is gonna sound stupid but where is the fuel pressure regulator? 99 3.8.
  7. #7 Re: Fuel problem
    Jul 2008
    VA
    found it, now how do i change it?
  8. #8 Re: Fuel problem
    Jul 2008
    VA
    nevermind again, snap ring, thanks for all the help.
  9. #9 Re: Fuel problem
    Feb 2008
    So, did this fix your problem?
  10. #10 Re: Fuel problem
    Jul 2008
    VA
    I forgot to update, I replaced the FPR and that seemed to make it run better but the idle was still not right so I pulled the IAC and cleaned all the carbon out and replaced the valve and shes all good now. Thanks everyone
  11. #11 Re: Fuel problem
    Hagerstown,Md
    Sweet, glad you got her fixed
  1. Another Fuel Gauge Problem
    By SilverGT in forum General Tech Discussion
    Last Post: 06-13-2012, 09:45 PM
  2. 03 GP 3100 sfi fuel problem?
    By dirtfan50 in forum General Tech Discussion
    Last Post: 09-26-2010, 04:51 PM
  3. Fuel pickup problem
    By g8rmark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-01-2009, 07:32 AM
  4. Fuel Pump Problem
    By ericrluoma in forum General Tech Discussion
    Last Post: 04-13-2009, 01:19 PM
  5. 97 gtp fuel gauge problem???
    By iwinagn in forum General Tech Discussion
    Last Post: 07-28-2008, 01:32 PM
