When you turn the wheel you are making a LOAD on the motor. The PS pump and pulley are on the belt system, so when you turn the wheel the PS is then trying to pump the fluid, its make the rpms drop alot more because you are not moving and the fact that the ground makes alot of friction and thus make the pump work harder and causes the rpm drop.
