Thread: 2001 gp gt
Results 1 to 5 of 5
  1. #1 2001 gp gt
    Dec 2010
    Iowa
    I have a 2001 Grand Prix GT Coupe Limited Edition that has 108,000 miles on it that is now hesitating on 1st and 2nd gear, only when warm....It never hesitates or feels sluggish when cold.....Mechanic told me it was my Catalytic Converter but I don't believe them.....going to change my plugs and fuel filter, neither of which have EVER been changed....Any ideas? The hesitation feels more like the engine is getting choked off and sputters until I let up off the gas....Any help would be greatly appreciated!
  2. #2 Re: 2001 gp gt
    HUDSON
    First thing I wold check for is a vacuum leak, check all hoses and vacuum connections for cracks, breaks, loosness. How is it at WOT?
    I don't know what the cat. converter would have to do with it unlees it was melted inside restricting flow, and that causes different problems. Not only that, if there was a problem with the cat. conveter, that means there is somthing else wrong too because converter do not just go gad, somthing has to cause there malfunction such as incorrect a/f ratio, or incompatable chemicals that harm the catalyst.
    What condition is the air filter in? PCV valve clean? throttle body carbon up?
  3. #3 Re: 2001 gp gt
    St. Louis
    I would def. start with plugs, wires, PCV valve, fuel and air filter replacement. Might clean the MAF as well. 2nd the notion for checking for vac. leaks as they are known to creep up around 100K from what I've seen (and experienced).
    Have the LIM/UIM gaskets ever been changed?
    Jay
  4. #4 Re: 2001 gp gt
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Why dont you think its the CAT? Its very Very common in these cars for the cats to clog
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  5. #5 Re: 2001 gp gt
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    theres a recall on the cat so you might as well go get it fixed cause its free and have fun with those plugs lol difficult to do on these cars
  1. Will these fit a 2001 GP?
    By Pontiac Warrior in forum Tires & Wheels
    Last Post: 12-09-2009, 03:30 PM
  2. 2001 GTP Trans into 2001 SE?
    By TechSmurf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-28-2009, 07:11 PM
  3. 2001 se
    By whaleyon sauce in forum General Tech Discussion
    Last Post: 07-31-2009, 05:09 PM
  4. looking at a 2001 gt
    By pontiac88 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-25-2009, 01:30 PM
