Thread: Rev limiter problems ????
Results 1 to 5 of 5
  1. #1 Rev limiter problems ????
    May 2011
    Selah Wa
    New GP owner just bought a 2002 GP GT 88600 mi. Car will not go above 4200 rpms if you are in drive or manually shifting the car with light,moderate or heavy acceleration it does not matter. Also in drive when you hit passing gear the transmission will kick down but will hang up at 4200 until you back off the gas a little then will shift into drive. Not sure if this is related but while in park if you rev the engine I get a rattling sound from the area of the catalytic converter but not all the time. And when I hit 4200 rpms I get a service engine soon light comes on but does not stay on. Nothing else seems wrong with the car or should I say nothing that I am familiar with have only had the car a few weeks any help guys
  2. #2 Re: Rev limiter problems ????
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Flashing CEL is usually a multiple misfire. Probably needs a tune up
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: Rev limiter problems ????
    St. Louis
    Yep. Plugs, wires, fuel and air filter. Then clean the MAF. Reset the computer once this is done and let it relearn and see what you get.
    If this doesn't solve the entire issue, then it may be a clogged cat.
  4. #4 Re: Rev limiter problems ????
    May 2011
    Selah Wa
    You think needing a tune up would cause the issue with rpms goin too give the tune up a try and thank you for the reply
  5. #5 Re: Rev limiter problems ????
    Definately.
    It's almost funny how many "transmission" problems can be fixed w/o touching the transmission.
    Tune up and holler if that doesn't clear it up.
  1. question about rev limiter
    By jersey jok3r in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2011, 09:11 AM
  2. ECU speed limiter possible?
    By PCweber in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-19-2010, 09:52 PM
  3. Limiter question..
    By Ninjo in forum General Tech Discussion
    Last Post: 11-03-2008, 11:24 PM
  4. Speed limiter?
    By Randy_W in forum General Tech Discussion
    Last Post: 05-23-2008, 09:58 AM
  5. Speed limiter @110 WTF???
    By ABINOK in forum General Tech Discussion
    Last Post: 03-20-2008, 08:55 PM
