Thread: Check engine light just came on this morning
Results 1 to 14 of 14
  1. #1 Check engine light just came on this morning
    SE Level Member sonyz92's Avatar
    Alfred, New York
    This morning while i was driving to school, my check engine light came on while i was climbing a very steep hill going 50 mph. now i hear a whining from the side the belt is on and a very faint knocking sound that wasnt there before. i checked the belt and its fine. does anybody have any ideas as to what may have happened??
  2. #2 Re: Check engine light just came on this morning
    St. Louis
    Maybe low on power steering fliud? Either that or a pulley going bad.
    And stop by an Autozone and have the code read and post it here so we don't have to guess at what the issue may really be.
    Jay
  3. #3 Re: Check engine light just came on this morning
    Get the code read first. It's free at about ANY autoparts store. Knocking doesn't sound good to me.
  4. #4 Re: Check engine light just came on this morning
    GT Level Member sasquatch094's Avatar
    cleveland
    haha you can say that again.. Some autozones arnt doing the free checks anymore, so just call before you waste your time going up there.
  5. #5 Re: Check engine light just came on this morning
    Alfred, New York
    Well! it must not have been a big deal. the light went away and stopped making that noise before i had time to go and get it checked. still wonder what it was tho
  6. #6 Re: Check engine light just came on this morning
    Alfred, New York
    The light came back on i just went to autozone and had a scan. this is what it said:
    P1404
    Definition - EGR Valve stuck open condition
    Explanation - While monitoring the EGR valve pintle position the ECM detected the closed position sensor voltage higher than the learned closed position voltage
    Probable cause - Failed EGR Valve, Carbon blockage of the pintle
  7. #7 Re: Check engine light just came on this morning
    Jul 2008
    sumter,south carolina
    i have a egr ill sell ya for 20 bucks.. has like 90k on it... worked fine when removed.
    02 GTP with mods 05 GP for DD
  8. #8 Re: Check engine light just came on this morning
    Alfred, New York
    i was thinking of seeing if i might be able to clean it out somehow since it says carbon buildup. would that work??
  9. #9 Re: Check engine light just came on this morning
    Jul 2008
    its possible... ur gonna need a new gasket either way.
  10. #10 Re: Check engine light just came on this morning
    Alfred, New York
    ahh darn. eh well 20 is wayyy better than spending the 150 they were asking for a bran new one. and from my understanding it seems easy to install myself. how would i buy it from you?
  11. #11 Re: Check engine light just came on this morning
    Jul 2008
    well first id have to dig through my parts closet and find it... then hopefully u have a pay pal acct. send me 20 and a few bucks for shipping. then i mail it to u. voila u have a good EGR lol
  12. #12 Re: Check engine light just came on this morning
    Alfred, New York
    i went and took the egr off and cleaned it out with carb cleaner and let it sit for the day. put it back on let the car warm up and drove for about ten minutes. when i was in park i noticed that it idles lower now?? between 1 or 2 notches below 1000 rpm is that normal?
  13. #13 Re: Check engine light just came on this morning
    Charles City, IA
    Idle should be at like 800, If it was at 1000 you have a problem.
    SMGPFC Two Nipple General
  14. #14 Re: Check engine light just came on this morning
    Alfred, New York
    oh good :] since i got the car it had been idling at 1000. it just seemed that now at 800 it ran a little rougher than before but its not very noticeable
  1. Check engine light on
    By CMURDAx in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2010, 10:11 PM
  2. check engine light goes on and off!!
    By stanggreg90 in forum General Tech Discussion
    Last Post: 06-19-2009, 12:37 AM
  3. check engine light
    By keenan00gtp in forum General Tech Discussion
    Last Post: 12-01-2008, 10:25 PM
  4. Check Engine Light
    By probuilder1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-27-2008, 08:28 PM
  5. Check engine light on
    By darkwingduck in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-18-2008, 07:59 PM
