Thread: can you run 1.9 rockers on a n/a engine?
Results 1 to 8 of 8
  1. #1 can you run 1.9 rockers on a n/a engine?
    GT Level Member mezzoni's Avatar
    Nov 2009
    Milford, CT
    theres 100 dollars off on the w-body store's rockers and it says to get split ratio rockers for n/a. does it matter or can i get the 1.9?
    2006 pontiac G6 GT coupe - the daily
    2001 pontiac trans am WS6 - pacesetter headers, slp exhaust, diablo sport tuner, ported throttle body, ported MAF, SLP intake lid, B&M shifter, UMI panhard bar, lowered on koni's
  2. #2 Re: can you run 1.9 rockers on a n/a engine?
    Florida
    You can run 1.9s on a N/A but youll make less power than with getting the split ratio.The 1.9s will give you only bout 10hp whereas the split will net 15-20 horsies.So you decide.
  3. #3 Re: can you run 1.9 rockers on a n/a engine?
    Nov 2009
    Milford, CT
    Hmmmm well I do plan on top swapping but I have no clue when... Maybe I'll just go with the split ratio for now then sell them or trade them if and when I decide to top swap
  4. #4 Re: can you run 1.9 rockers on a n/a engine?
    Florida
    Thats a good idea.But since you said youll top swap eventually then go with the 1.9s.They are suitable for supercharged cars and net you 20+ hp once you're supercharged.
  5. #5 Re: can you run 1.9 rockers on a n/a engine?
    ER's dont net that kind of power...
    16 WHP from ER rockers.
    1.9's are 13 WHP.
  6. #6 Re: can you run 1.9 rockers on a n/a engine?
    1.9's are for the blower cars.
    IMO, get the ER rockers with a HV3...and a 3" DP...it wins...for an N/A car it makes a TON of a difference...maybe a shift kit and a custom tune and new mounts next. Should easily run high to mid 14's from there...since yours is the freak one that went 15.3 basically bone stock.
  7. #7 Re: can you run 1.9 rockers on a n/a engine?
    Charles City, IA
    Just save for a cam.
    SMGPFC Two Nipple General
  8. #8 Re: can you run 1.9 rockers on a n/a engine?
    Just save for BOOST...
    furrealz doood
  1. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  2. i finally debaged the rockers and de-riced the engine bay!
    By kyle99gtp in forum Visual/Body Modifications
    Last Post: 07-26-2008, 04:29 PM
