Thread: Noise when revved
Results 1 to 10 of 10
  1. #1 Noise when revved
    GT Level Member dengnath's Avatar
    I am new to the GP world. I used to have a park ave with the 3.8 s/c but it spun a rod bearing. So im taking another round with an 04 Grand Prix GT (couldnt afford a gtp) I bought it for $6200 from a Wilde Toyota which as a HUGE used car collection. It has 91,000 miles on it and came up to Wisconsin from North Carolina in 2008. Its got 2 blemishes on the outside but i figured it was a good deal. However, i have noticed a little bit of a clanky/popping noise from what sounds like the exhaust system when revved and is cold or has been cooling for a while. When the car is hot it will not make the noise. I am worried it is coming from the Catalytic converter. Is this something i need to be concerned about or is just hot air flowing through a cold exhaust? keep in mind i am in Wisconsin and right now it is getting down to the low 40's and high 30's.
  2. #2 Re: Noise when revved
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    probobly just the metal expanding and contracting when getting hot and cold
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: Noise when revved
    Brewcity, WI
    coud be the down pipe exhaust flange gasket.... mine is leaking there.
    Where in WI are you?
    And iirc, the cat-conv have a warranty of 6 years 120K... not positive on those numbers?
    Self-denied SMGPFC member #1
    SEARCH works!
  4. #4 Re: Noise when revved
    I am in oak creek, which is just south of milwaukee. Would the flange gasket be covered under that warranty, and is it transferable because im not the original owner of the car?
  5. #5 Re: Noise when revved
    Nov 2009
    Grand haven
    All warrantys are different in there virbage so I would check. Can you get a vid of what sound it is making?
  6. #6 Re: Noise when revved
    i will try. it is really hard tho because i have to revv it and be down by the side to catch the sound.
  7. #7 Re: Noise when revved
    Asking the maybe obvious question here. why are you revving a cold engine?
  8. #8 Re: Noise when revved
    Because.
    It's race.
  9. #9 Re: Noise when revved
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    agreed...why are you?
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  10. #10 Re: Noise when revved
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Could it be a bad pulley?
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  1. GTP Noise....
    By SuperCharged0nE in forum General Tech Discussion
    Last Post: 04-02-2010, 12:01 PM
  2. odd noise at 27 mph
    By rossscrappy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2010, 06:01 PM
  3. noise
    By roadwarrior1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-15-2009, 03:21 PM
  4. This noise
    By pontiackid in forum General Tech Discussion
    Last Post: 06-11-2009, 11:41 AM
  5. .... Noise again
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-24-2008, 04:15 AM
