Thread: Maybe a misfire?
Results 1 to 13 of 13
  1. #1 Maybe a misfire?
    GT Level Member Brammer's Avatar
    Feb 2009
    Roanoke, VA
    2002 GP GT, 107,xxx; Started what I THOUGHT was misfiring. Would ride as normal then would stutter almost and rpms would momentarily drop, would do it more prevalent under heavy acceleration. Just changed plugs and wires, didn't change coils. Started happening again. I added fuel system cleaner and 93 gas to make sure it's not something there......same thing......what could be my problem? Could it be transmission? Not throwing any SES codes......
    Any help would be greatly appreciated.
  2. #2 Re: Maybe a misfire?
    Feb 2009
    Roanoke, VA
    No one? I'm at a loss.....fuel pump/filter? Coils? Any ideas?
  3. #3 Re: Maybe a misfire?
    so the tach has dropped to zero while driving??
  4. #4 Re: Maybe a misfire?
    Feb 2009
    Roanoke, VA
    nope the rpms just dip when it happens and picks right back up right away. This might not make sense but you know how when you start a car it makes the belt squeal kind of sound. It does that when the rpms dip like that....but just faintly.
  5. #5 Re: Maybe a misfire?
    GT Level Member stevenk8's Avatar
    Macomb MI
    Check the injectors, my car was doing something almost like yours come to find out i had a huge misfire and my car was running off 4 cylinders
    2002 grand prix gt (CAI,180*tstat,MSD wires,magnaflow high flow cat,ubend delete,18in wheels,HID headlights and fog lights)
    More mods soon to come!
  6. #6 Re: Maybe a misfire?
    Feb 2009
    Roanoke, VA
    how do I go about checking the injectors?
  7. #7 Re: Maybe a misfire?
    Feb 2009
    Roanoke, VA
    And its only sporadic. The car still pulls hard sometimes. Other times when trying to go wot it just drops all of a sudden.
  8. #8 Re: Maybe a misfire?
    Feb 2009
    Roanoke, VA
    Update I replaced all three coils......same issue. Any other ideas?
  9. #9 Re: Maybe a misfire?
    Albertq,Canada
    What spark plugs did you use?
  10. #10 Re: Maybe a misfire?
    Feb 2009
    Roanoke, VA
    Denso platinum twin tip....regardless the issue was present before the plugs and wires.
  11. #11 Re: Maybe a misfire?
    GT Level Member rmcardle3's Avatar
    Houston, TX
    But no codes at all when using a scanner? I know you said no SES but I wasn't sure if you just mean't no SES "light" or no light AND no scan code, either way no codes though, right?
    2000 GRAND PRIX GTP (Sedan)
    MICHELIN Pilot® Sport A/S Plus 245/50 ZR16 97W M+S
    Cone Intake, SD Headers
  12. #12 Re: Maybe a misfire?
    Pull the codes, there are many that don't turn on the light. There are too many things that could be wrong to try and desktop diagnose it with the provided info.
  13. #13 Re: Maybe a misfire?
    Houston, TX
    ^^Pull them (even when no SES, it's free at Autozone and Advanced)
    GL and post back results here.
  1. HELP PLEASE! Misfire at 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2013, 05:34 PM
  2. 98 gtp misfire need help:(
    By mskram1 in forum General Tech Discussion
    Last Post: 02-02-2011, 01:06 PM
  3. Very Bad Misfire
    By SDGTP99 in forum General Tech Discussion
    Last Post: 05-12-2010, 09:17 PM
  4. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  5. Misfire like no other
    By MTXGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2008, 10:02 AM
