Thread: what is the best way get this fix
Results 1 to 9 of 9
  1. #1 what is the best way get this fix
    TN
    Today I installed a reptile ported tb on my gt and after takeing the old one off I found out the helix tb spacer's gasket[that i put on a year and half ago] was about to give again. I know most people think spacers are not worth anything but I did fell a diffence in respouse and a little power just few horses. Need something that I can trust not to leak I dont need to change the plugs out again because this isnt the first time this has happen.
  2. #2 Re: what is the best way get this fix
  3. #3 Re: what is the best way get this fix
    Nov 2008
    Chicago
    I've always had good luck with the GM gaskets
    97 GTP Sedan: 3" from the downpipe to the mufflers, no cat, ADR 17's, AGX/Eibach, HAI w/k&n, 6k HID's
  4. #4 Re: what is the best way get this fix
    TN
    Quote Originally Posted by FuglyGTP View Post
    Got a question about that the only gasket for the tb is one that fits that fit into the groove on the interior side of the tb not between the two flats sides of the spacer and tb just saying I zzp has one but i tried it but thats the reason I started this post thanks for trying
  5. #5 Re: what is the best way get this fix
    Maybe you should explain this if you plan to stick around the site kinda BS if you ask me.
    http://www.grandprixforums.net/hey-s...tml#post433233
  6. #6 Re: what is the best way get this fix
    on the TB to spacer side of an L36.... you can't use the factory gasket because its a rubber insert for the upper plenum. Use RTV.
  7. #7 Re: what is the best way get this fix
    Charles City, IA
    The right stuff rtv.
    SMGPFC Two Nipple General
  8. #8 Re: what is the best way get this fix
    TN
    sounds like I need to just buy some rtv and try it then thanks everyone
    and just wondering anybody else have this problem
  9. #9 Re: what is the best way get this fix
    GT Level Member Deviq's Avatar
    SE WI
    Quote Originally Posted by zildjian102
    .. friggin trashy people. I did stuff with their daughter
