Thread: car idles shakes
Results 1 to 3 of 3
  1. #1 car idles shakes
    Canada
    hi guys,
    my 2000 3.8L , has engine code p0107 absolute manifold pressure and feels like it wants to stall???
    does anyone had that code before and that symptom?
    any help would be greatly appreciated.
  2. #2 Re: car idles shakes
    St. Louis
    Yep. Replaced my MAP sensor and it cleared up some. I had to look at it closely to see that the body of the sensor had actually separated from the bottom half and was bad. Also check for any vacuum leaks (check the back of the upper intake where the large hose comes from the brake booster). I also had a vac. leak at the map sensor housing on the upper intake. Replaced the PCV valve (including o-ring), the large o-ring in the housing and it took care of it.
    Let me guess, if you two-foot it and raise the idle to say 1000 rpm, then it smooths out and idles fine?
    Jay
  3. #3 Re: car idles shakes
    Canada
    yes it does the same thing if i rev it up to 1000! i did find my sensor kinda leaking a bit?? then that must be the issue
  1. 02 GP Shakes upon accelerating
    By riddell87 in forum General Tech Discussion
    Last Post: 01-08-2010, 11:11 PM
  2. gtp shakes/ vibrates
    By backinblackgtp in forum General Tech Discussion
    Last Post: 12-13-2009, 01:42 AM
  3. 01 GTP. Car shakes when in Neutral and Park.
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2008, 03:00 AM
  4. Car shakes after lowering
    By Smokedgtp in forum Brakes/Suspension/Chassis
    Last Post: 04-30-2008, 09:17 PM
