Thread: Lawngoose's Replacement Engine Advice/Question Thread
Results 1 to 20 of 23
  1. #1 Lawngoose's Replacement Engine Advice/Question Thread
    Outer Space
    So, I spun a bearing on my L67...and need a replacement engine on a budget. <800 if possible.
    Some of the knowledgeable guys on here recommended me to check out L26's since the rods are better..etc.
    Questions that have come to mind.
    • Would my s1x cam/105# be ok for this application?
    • Should I buy a complete block? w/heads, etc... or just the actual block... and swap my stuff over? Everything swap over fine?
    Any insight and removal advice is appreciated!
    02 GTP 13.6 @ 100mph - SOLD
  2. #2 Re: Lawngoose's Replacement Engine Advice/Question Thread
    If your heads are fine...which...if you spun a rod bearing you should be...I'd try and find a L32...and toss your heads with the #105's on it. Or a L67...up to you. L26 is higher compression so your going to need to go way higher on the pulley size...you'd be lucky if you got away with a 3.5" on that setup.
    As for removal...one thing to keep in mind...pay attention to the knock sensors because it is pretty easy to rip those wires clean out. Also...if you've never had the transmission out...have fun with the b1tch bolt...I'd go through the passenger side wheel well with a good 2 feet of extensions.
  3. #3 Re: Lawngoose's Replacement Engine Advice/Question Thread
    Outer Space
    I have pulled the engine and tranny out of the top. We left the ***** bolt out last go around. I found a complete 70k L26 shipped for 500. L32 and L67's seem to have higher miles and cost more.
    Part of me is thinking to just reuse my headers and throw the s/c on it. As much as I want to reuse my cam and springs... I might just sell them.
  4. #4 Re: Lawngoose's Replacement Engine Advice/Question Thread
    what is with this crazy throwing of the bearings?
    I vote n/a block + headers + blower. it'll be quite a bit slower but it'd still be decently quickish.
  5. #5 Re: Lawngoose's Replacement Engine Advice/Question Thread
    Outer Space
    I would have to swap lim right? No problems there?
  6. #6 Re: Lawngoose's Replacement Engine Advice/Question Thread
    Charles City, IA
    Use your heads and lim.
    SMGPFC Two Nipple General
  7. #7 Re: Lawngoose's Replacement Engine Advice/Question Thread
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    You dont need to spin the blower as fast to make the same amount of power on a higher compression build(less heat at the outlet, more efficient on the m90). Look at all the faster m90 cars.....there almost all high compression builds. A 3.5 pulley is making about what a gtp makes on a 3.3 3.2 setup. So keep that in mind as you do your Supporting mods setup. Also the higher compression engines (atleast on mine) prefers more timing then boost.
    Get the block if there willing to just sell the block. Slap your cam and heads and blower on. Start with a 3.6 pulley and work your way down as fit.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  8. #8 Re: Lawngoose's Replacement Engine Advice/Question Thread
    Outer Space
    I found a complete L26 heads and all. Any problem running L26 heads?
  9. #9 Re: Lawngoose's Replacement Engine Advice/Question Thread
    no injector bosses?
  10. #10 Re: Lawngoose's Replacement Engine Advice/Question Thread
    Hagerstown,Md
    Yep you need to run your old motors heads and LIM and Blower. Cant use the l26's because of the reasons Matt's outlined
  11. #11 Re: Lawngoose's Replacement Engine Advice/Question Thread
    Outer Space
    Quote Originally Posted by 01gpgt01 View Post
    Ok, well if I gotta take the heads off..might as well put the cam back in (assuming it's fine).
  12. #12 Re: Lawngoose's Replacement Engine Advice/Question Thread
    Matt outlined something right? Huh...lol
    Anyways...yes...I'd grab the L26...you've just gotta compinsate for the higher compression...meaning headers are a must...and while your blower is off if you haven't done it I'd port it and the TB too. I'd start on a stock sized pulley and go down from there but I don't see any issue with you running a 3.5" with a cam and headers.
  13. #13 Re: Lawngoose's Replacement Engine Advice/Question Thread
    Donating Users kfish's Avatar
    Ohio
    im running a 3.4 on a top swap with an xp and headers, with 19* of timing. i dont know much about the s1x though.
  14. #14 Re: Lawngoose's Replacement Engine Advice/Question Thread
    Outer Space
    Just bought the 74k complete L26 for $499.60 shipped.
  15. #15 Re: Lawngoose's Replacement Engine Advice/Question Thread
    so boost?
  16. #16 Re: Lawngoose's Replacement Engine Advice/Question Thread
    Outer Space
    so boost?
    Yep, gonna sell my 3.2 & 3.3 pulley. Gonna start with a 3.6. Gotta figure out what to do about the flexplate next. Im still reading up on it...
  17. #17 Re: Lawngoose's Replacement Engine Advice/Question Thread
    I THINK...since its a L26 your supposed to use the L26 flexplate since they are balanced differently...but I'm not 100% sure...
  18. #18 Re: Lawngoose's Replacement Engine Advice/Question Thread
    no, you need to use the flex plate that matches up to your transmission. so youd have to reuse your flex plate.
  19. #19 Re: Lawngoose's Replacement Engine Advice/Question Thread
    But for god's sake get new flywheel bolts.
  20. #20 Re: Lawngoose's Replacement Engine Advice/Question Thread
    Outer Space
    Talked with Dave @ TEP. The L26 flywheel will work for my existing TQ converter. However, I do have an extra N/A TQ converter that came with my tranny last January.
    So far I need the following:
    - Head Gaskets (most likely the GM ones)
    - Lim Gasket? (Maybe...mine has like 10k on it)
    - 3.6 Pulley
    - Flexplate bolts
    So all in all, I should have the engine removed by this weeked. And I am hoping to have the replacement in by the following week. Really depends on work and if I can get some extra bodies around to help. I would rather take longer getting it right...then having to do it over.
    Thx everyone for your replies and support!
  1. just another headlight question thread
    By CMURDAx in forum Visual/Body Modifications
    Last Post: 08-01-2010, 10:08 AM
  2. gtp engine replacement
    By turbo6 in forum Off Topic Discussion
    Last Post: 06-04-2010, 08:14 AM
  3. Front to rear brake line replacement - need advice
    By bxfl in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2010, 09:56 AM
  4. Need advice on engine build.
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 06:40 PM
  5. Thread tagging question
    By Abrasive in forum Forum Bugs/Suggestions
    Last Post: 02-28-2008, 02:54 PM
