Thread: HV3 install Question
Results 1 to 17 of 17
  1. #1 HV3 install Question
    Nov 2009
    Platteville
    Ok, I've been looking into my HV3 install, I see that I have to unbolt the fuel rail and alternator to lift off the UIM. I read that while I have those off, I should replace the o-rings on the injectors. Do the injectors just lift out with the fuel rail, or do the o-rings sit between the fuel rail and the injectors?
    Thanks for the help,
    Kevin
    Signature size too big, please resize and try again. - Management
    Bright Red 2001 Grand Prix GT w/ Thrasher CAI + 180* T-stat + AP104's + ZZP Wires + (Coming soon) ZZP Downpipe + Reprogrammed PCM
  2. #2 Re: HV3 install Question
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    O-rings are attached to the injector. They will come with the rail when you pull it
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: HV3 install Question
    Feb 2008
    I got mine out fine without removing the alternator. And I also didn't change the O-rings, I just inspected them and made sure I was careful putting them back in. No problems so far. Car is relatively low miles though... 45k on an 04 monte
  4. #4 Re: HV3 install Question
    GTX Level Member cerick08GP's Avatar
    The others posts are correct, but I’m throwing in my hat in ring.
    The fuel rails, injectors and O-rings come out as a unit. However, I recommend get new O-rings. They are cheap and easy to replace so why not. BTW, I cut one of my O-rings during my HV3 install.
    The alternator can stay no reason at all to remove it.
    Oh, and as a fair warning don’t believe the ZZP website for a second on the half an hour job quote. More like 2-3 hours for a first timer.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  5. #5 Re: HV3 install Question
    Nov 2009
    Platteville
    Well, it doesn't sound too bad then. I'll pick up some o-rings at O'reilly's probably then. So all I have to do then, is the following:
    Unplug sensors (I believe 3 sensors are necessary)
    unbolt fuel rail
    lift fuel rail away
    unbolt throttlebody
    unbolt UIM
    lift
    install
    replace gasket
    replace injector o-rings
    Correct me if i'm wrong.
  6. #6 Re: HV3 install Question
    Don't know why you have to remove the Throttle Body...should just have to remove the throttle cables...
  7. #7 Re: HV3 install Question
    and that stupid bracket that connects the TB to the LIM.
  8. #8 Re: HV3 install Question
    Nov 2009
    Platteville
    alright. gotcha!
  9. #9 Re: HV3 install Question
    Dec 2008
    Lawndale, CA
    I left mine off when I did the HV3 install.
  10. #10 Re: HV3 install Question
    Mine disappeared a long time ago...
    Seriously dont know where it is.
  11. #11 Re: HV3 install Question
    Grand Island, Nebraska
    It took me and a friend literally 30 mins to do the hv3 install...and it usually takes us a long ass time to do anything. i didnt replace my o-rings even though i probably should have. enjoy the awesome NA power, or what little of it there is
  12. #12 Re: HV3 install Question
    SE Level Member SSJon's Avatar
    Fargo/Moorhead
    Not to threadjack, but did you guys even notice a difference with the insert?
    '00 Monte Carlo SS
  13. #13 Re: HV3 install Question
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    i noticed a big diff when i did my mods but i did hv3 plog and dp at the same time i whent from 16.7 stock 1/4mile to 15.4 with just the 3 mods then added l67 tb and poly mounts and got best time of 15.2 on stock pcm
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  14. #14 Re: HV3 install Question
    Quote Originally Posted by SSJon View Post
    Yes, beyond noticeable in fact. My “new” GP had tons of low end power, but when passing people on the highway is was a dog. Especially with no skip shifts, it was double dog slow. The HV3 gives lots more passing power, and the low end still has more than enough punch. The only down side of the mod is paying $200 for a big piece of plastic and a seal. It is great mod, ZZP gets some stuff right. hehe
    2008GP
    2002GP||sold
  15. #15 Re: HV3 install Question
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    man i hope to god zzp still has these in february when i get my tax money back!! i noticed they dont sell the PLOG anymore
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  16. #16 Re: HV3 install Question
    Ya...but you can buy headers just about the price of a PLOG now...and get way more power...just a little FYI
  17. #17 Re: HV3 install Question
    QFT
  1. SD Headers install question
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2010, 12:51 PM
  2. FIPK install question
    By dgs02gtp in forum Introductions/Noob Questions
    Last Post: 07-31-2009, 12:04 PM
  3. Homemade FWI Install Question
    By High Rolling GTP in forum General Tech Discussion
    Last Post: 02-01-2009, 08:51 AM
  4. Total lift after rocker install.Question
    By TDCRacing in forum General Tech Discussion
    Last Post: 12-06-2008, 04:03 PM
  5. 3" Downpipe install question
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2008, 07:21 AM
