Thread: LIM Gasket, Head Gasket, or bad sensor?
Results 1 to 20 of 20
  1. #1 LIM Gasket, Head Gasket, or bad sensor?
    Feb 2009
    Boston
    I've been researching and troubleshooting this problem for weeks now but I'm starting a job 1.5 hours from home tomorrow and don't trust the GP right now. So to the rental agency I go!
    But on a serious note, I honestly can not find a solution to the problem (which yes there could be more than one). But any and all input would be quite beneficial and appreciated. Here is the problem:
    Car: 1999 GP GT, 3800 VIN K with 102K
    Stalling. Over the summer, I was driving the car maybe once a week ... in stop & go Boston city driving. The car would stall 2-3 times on a 5-10 mile trip when coasting or at a stop. I figured b/c not driving it often, the computer wasn't adjusting properly. I've been driving it daily the past 2 weeks and seemed to have fixed itself. Initially it was at city speeds, but also died on me on a highway trip going 60 mph. Vacuum fitting are somewhat corroded, but I have siliconed everything I could find until I can afford a new set ($200 from the dealer!)
    Ticking. In the past month, ticking has been coming from the lifters. At first it seemed to be coming from the front, then more recently from the back. It would go away though after pressure built up. Low oil? Low oil pressure? Either or... I did a change last week and the problem has seemed to vanish.
    Overheating / Leaking. I put in a new thermostat and radiator cap in after the cap blew about 18K mile ago. Good to go. After the oil change last week, the car seemed fine. After a 400 mile trip over 3 days though... I have some serious overheating/rough idle issues.
    - Cap was bad again. Replaced and now have vacuum pressure (I could squeeze the upper radiator hose completely before).
    - However, now the car warms up and warms up fast. I can sit on the gas at about 2K rpm in the driveway and the car will be up to 210F in under a min from a dead cold start. And after 5 min of 40 mph driving, its over 235F but not "overheating".
    - Low coolant. Light has been on for over a year so I lost faith in that aspect awhile ago. I've put a gallon of Dexcool in the past week both from the reservoir and straight into the radiator from the cap though. Still very low (reservoir empty this morning) and NO signs of leaks under the car.
    - No white smoke from the tail pipes, but a lot of condensation on hands.
    - The car is sluggish.. had complete loss of power at 25 mph yesterday from cold start. Pulled over, turned off and on.. and I got home ok. Still idling/running somewhat rough.
    - Wouldn't start... once. When car "overheated" to about 240-245F, I pulled over and shut her off for about 5 minutes. I know the computer shuts off coils/cylinders? in this instance to prevent further damage.. but it wouldn't start at all. It would struggle for gas it seemed and would cut right out. After a minute and giving it some gas (2-3K rpm) it finally started but was really struggling to stay running. I limped home.
    - No signs of coolant in oil. No milky-ness. Fresh oil change, bad or good to decipher?
    These (-'s) are my symptoms. Out of everything I have found... I think its the LIM gaskets. Could be easy fix, but want to be reassured before I waste time and money. But from reading the forums, it could be a Head gasket, a sensor of any sort (MAF, radiator temp, ...??), or even the computer could be bad or needs to be reflashed.
    Any and all help would be appreciated. Although I don't post or respond that much, I read them all the time.
    Fiske
    95 Taurus SHO ATX - 121K
    99 Audi 2.8 Quattro - 113K
    99 Grand Prix GT - 83K
  2. #2 Re: LIM Gasket, Head Gasket, or bad sensor?
    If your LIM gaskets have never been changed then do that and see if it improves.
    Guy at work had this issue, changed the LIM gaskets and put a new upper plenum on (old one warped) and it runs a million times better now.
    Make sure you get the aluminum ones.
    But if you want to be sure about the head gaskets do a compression test and/or leak down test.
  3. #3 Re: LIM Gasket, Head Gasket, or bad sensor?
    Feb 2009
    Boston
    For a leak down test, you use a 'leak down tester' correct? If so, where do you get one because Autozone didn't have one to rent?
    Fiske
  4. #4 Re: LIM Gasket, Head Gasket, or bad sensor?
    You're supposed to,
    But you can just get a compression tester kit that lets you use a quick disconnect for a compressor air line.
    Then you do the compression test then if you find anything wrong, fill the cylinder with air and listen to see where it leaks. you can take the spark plug out of an adjacent cylinder and put your finger near the hole to see if you feel any air pushing by.
    If its the valves you can hear it in intake or exhaust.
  5. #5 Re: LIM Gasket, Head Gasket, or bad sensor?
    GT Level Member 91gpse's Avatar
    warren, mi
    sounds like it could be the gasket.... heres a quick test to tell if its a lower intake manifold gasket... take your oil cap off... take your finger and rub the inside of the valve cover.... if the oil on your finger looks like pudding.... trust me it will if the gaskets bad... i had gallons of the stuff in the motor when i did the gasket in my grand am... itll be thick and milky....its from the oil absorbing the water from the coolant...
  6. #6 Re: LIM Gasket, Head Gasket, or bad sensor?
    If you're loosing a small amount of coolant and compression is okay and you're not losing it externally then its your LIM gasket.
  7. #7 Re: LIM Gasket, Head Gasket, or bad sensor?
    Feb 2009
    Boston
    Oil is not milky which is why I think LIM. Water is coming out of the exhaust at a slow rate, but doesn't smell sweet if it was coolant.
    Fiske
  8. #8 Re: LIM Gasket, Head Gasket, or bad sensor?
    warren, mi
    Quote Originally Posted by GTFiske View Post
    if your doing the manifold gasket yourself you might wanna do the headgasket as well just to be on the safe side. a failed head gasket would explain why theres no leaks yet the coolant is always low as well as water/white smoke...
  9. #9 Re: LIM Gasket, Head Gasket, or bad sensor?
    you do know combustion results in H2O right?
    I still vote you replace the LIM gaskets, mine were shot at 81 K.
  10. #10 Re: LIM Gasket, Head Gasket, or bad sensor?
    Feb 2009
    Boston
    I'm gonna do the LIMs and MAF. Cheap and quick enough.
    Where can I buy an aluminum plenum? Haven't looked toooo hard but google isn't showing any immediate help/
    Fiske
  11. #11 Re: LIM Gasket, Head Gasket, or bad sensor?
    Willoughby, Ohio
    maybe a junkyard but that would be hard to find, maybe in the for sale section on the home page? some1 could be selling the top end after a top swap
  12. #12 Re: LIM Gasket, Head Gasket, or bad sensor?
    SE Level Member SSJon's Avatar
    Fargo/Moorhead
    You don't need an Aluminum Plenum, just a good plastic one the is not melted between the two coolant ports and the EGR port, located on the bottom side close to where the T/B connects. Yours may or may not be damaged, I have pulled several apart and only seen 2 failed upper plenums.
    For the LIM gaskets make sure to get the Aluminum style from either Felpro or AC Delco
    '00 Monte Carlo SS
  13. #13 Re: LIM Gasket, Head Gasket, or bad sensor?
    lim gasket explains that and is much more common....
  14. #14 Re: LIM Gasket, Head Gasket, or bad sensor?
    warren, mi
    true.. but what has me is the fact he said that there is no water in the oil. usually when the gasket fails youll get coolant mixed in with the oil.... i mean ive done several lim gaskets before... 3100s 3400s 3800s/scs and they all had water in the oil.
    edit... i got a pic of what the stuff looks like if you want a comparison....
    take your valve cover off and look and see if the oil looks like the stuff in this pic... this is a very severe case of the gasket failing and it probably wont be as bad but the oil might look close....
    http://i1045.photobucket.com/albums/...oto-0194-1.jpg
  15. #15 Re: LIM Gasket, Head Gasket, or bad sensor?
    i didnt read your book, i might later. sorry im not actually contributing to this thread, BUT...
    THANK YOU for being one of the only people in the history of the internet to actually describe what is going on in extensive detail in all areas. you are a master of your craft.
  16. #16 Re: LIM Gasket, Head Gasket, or bad sensor?
    I realize what you're saying but in my case the oil was 100% clean.
    Yet when i tore it down the LIM gaskets were indeed shot.
    Friends car was running just as poorly as described here and it needed a new upper plenum and LIM gaskets.
    Compression test would tell you right away if you have a head gasket issue.
  17. #17 Re: LIM Gasket, Head Gasket, or bad sensor?
    Feb 2009
    Boston
    For those who read this in the future with any of the above symptoms.. the problem turned out to be the Upper Intake Manifold (Plenum). When the old one was taken off, the LIM was FILLED with coolant. Scary stuff.. it could've ruined the motor. Luckily it wasnt running when it hyrdolocked.
    An easy way to test is to take off the the intake... open up the throttle body to see any signs of coolant (fresh or residue). But that isn't always the case.. just mine.
    For those who don't know (which I didn't prior to this) the plenums are defective and melt/corrode fast around the EGR valve. The new valve is much narrower so the heat of the aluminum won't melt the crappy plastic intakes.
    New LIM gaskets, UIM/plenum with new gaskets, thermostat, plugs, and 3 oil changes... the system is running great. SES light went off on its own and now getting 25+ mpg.
    Fiske
  18. #18 Re: LIM Gasket, Head Gasket, or bad sensor?
    warren, mi
    dang.... learn something new everyday.... was it sorta like a black sludge looking stuff? because ive had that coming out of my throttle body before. i just cleaned it out and didnt really think much of it.... ill have to check my egr if thats the case you think just changing the egr will prevent it from failing totally?
  19. #19 Re: LIM Gasket, Head Gasket, or bad sensor?
    Feb 2009
    Boston
    It was weird.. it was literally straight dexcool coolant ON TOP of the lower intake manifold. Oil I believe is a sign of the head gasket beginning to deteriorate.
    The throttle body had crusted orange/pink residue in the grooves and around the sensor. But there was a black build up on inner side of the throttle body.
    For the EGR valve.. you could replace it to prevent any further damage. But you should check the plenum when you have it off anyway to see any signs of corrosion around the valve. The two holes opposite each side of the actual valve was where the problem truly was. The coolant was boiling around the valve to the point that it would splash up and corrode it. Over time.. it just completely wore through the gasket and plastic.
    Fiske
  20. #20 Re: LIM Gasket, Head Gasket, or bad sensor?
    warren, mi
    i just replaced my headgasket not too long ago it blew... so it explains the black sludge. that was there before it blew though.... i replaced my egr there wasnt corrosion on the manifold but there was on the egr im getting better gas milage and its running smoother too. this a problem with any 3x00 motor? btw the whole corrosion issue is new to me never heard of it happening before.
  1. bad head gasket?
    By nscottp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-08-2009, 08:51 AM
  2. 98 gtp bad head gasket
    By nscottp in forum Off Topic Discussion
    Last Post: 09-07-2009, 12:40 AM
  3. Head Gasket? Or LIM ??
    By JAllegar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-08-2009, 08:50 AM
  4. head gasket?
    By Mikefisher in forum General Tech Discussion
    Last Post: 10-10-2008, 12:36 PM
