Thread: speedo acting up
Results 1 to 7 of 7
  1. #1 speedo acting up
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    ok the problem i am having is that my spedo wont work all the time and it willl randomly work any ideas i know its not the sensor on the diff
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  2. #2 Re: 2001 grand prix gt
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    seems like maybe the cluster if its not the speed sensor. do u have a computer to hook up to see if it reads vehicle speed properly? if its not the speed sensor, i would say cluster. i guess it could be wiring sumwhere.....
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  3. #3 Re: 2001 grand prix gt
    ya my little scanner can read mph and rpm and it att reads right but i drove all the way from work and it worked the whole way so im not sure whts going on
    sold 97 GTP stock
  4. #4 Re: 2001 grand prix gt
    SE Level Member chev1988rolet's Avatar
    Jul 2010
    TX
    can it be a faulty ABS computer module? A while back I read online about the speedometer sensor passing through the abs before it gets to the cluster. my speedometer dont work either, been using scanner for a year now. I unplugged harness from abs and saw that some pins were burnt. I took off the cluster and gave 12 volts to some of the pins on it and the gauge would move from 0 to 110 when touching the right pins. you should borrow a cluster from a friends grand prix and see if its that. that way you wont spend money on a part you dont need.
  5. #5 Re: speedo acting up
    i changed your title so people actually cared what you were asking about.
    i cant help...
  6. #6 Re: speedo acting up
    Me either but if I had to guess I'd look at the speed sensor
  7. #7 Re: speedo acting up
    thanks bio and iy was acting up again yesterday so for the hell of it i hit the top of the dash above the speedo and it worked for a second would it be just a losse conncetion in the dash
    sold 97 GTP stock
  1. Hi im a new guy. 2001 Grand Prix SE
    By MV4824 in forum Introductions/Noob Questions
    Last Post: 07-18-2010, 02:07 PM
  2. 2001 Grand Prix GTX: Value
    By jack333 in forum Introductions/Noob Questions
    Last Post: 02-04-2010, 01:43 AM
  3. 2001 Grand Prix
    By jfleming01 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-27-2009, 10:39 AM
  4. Hello im new i own a 2001 grand prix gt
    By Jesse1 in forum Introductions/Noob Questions
    Last Post: 10-14-2009, 03:46 PM
  5. 2001 grand prix TCC help
    By lynnjones in forum Introductions/Noob Questions
    Last Post: 07-25-2009, 06:24 PM
