Thread: Custom vacuuming for Gen V Top Swap???
Results 1 to 3 of 3
  1. #1 Custom vacuuming for Gen V Top Swap???
    GT Level Member uNda6gT's Avatar
    Jan 2009
    Baltimore
    Now I have almost all the parts for the top swap, but I was riding pass the junk yard today and spotted an 04 Comp G and I REALLY REALLY want that Gen V out of it but how much more extra work would I have to do get that hooked up? I read in the sticky about custom vacuum lines... how difficult would this be?
    02 Pontiac Grand Prix GT:Intake,SLP Powerflo Catback,HV3,DHP PCM, 15.3 @89mph
    96 z28 Geared Stalled Bolt On......Typical
  2. #2 Re: Custom vacuuming for Gen V Top Swap???
    Jersey
    not difficult, you need to choose if you want to block off evap and run the L67 t/b or block it off (if you choose to run a N* or Ls1 t/b). Next, your going to have to run pcv, either block it off and run a breather (i hate breathers) or use it by tapping in somewhere between the t/b and blower (after maf, so its metered). You might want to think about doing a N* or Ls1 t/b while your at it.
    my car has a N* and LQ4
    also, read through this
    ClubGP Message Forum troubleshooting
    16' wrx sti- stock
  3. #3 Re: Custom vacuuming for Gen V Top Swap???
    GTP Level Member
    Pittsburgh
    Quote Originally Posted by 99prixgt View Post
    if you do it, you can run the STOCK gen V Evap on the back side of the blower and block the L67 TB. Personally i would run the Northstar TB so that the Inlet of the Gen V matches the Northstar TB. That is the easiest way.
    If you run the Northstar the STOCK GenV Evap is with out a question the way to go.
    After that the PCV in the Gen V can be used EXACLTY like the stock Gen 3 blower. If you are running the L67 TB then you have to have a fresh air inlet before the throttle blade. IF you have the Northstar you can connect it to the Barb on the TB....No modification needs to be made to the PCV system
    2003 SSEi,
  1. Replies: 0
    Last Post: 03-07-2010, 09:14 PM
  2. custom cam
    By justwhisen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2008, 08:22 AM
  3. Custom FWI
    By 03GTPFour in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2008, 01:32 PM
