maf = unplug and see if the car runs better.
if it does, your maf is bad.
Also, the MAF is frequency based... so have fun with that.
The TPS is voltage but there is a notice thing from GM saying that the TPS may fail because the voltage spikes so quickly it throws the ECM off and causes a poorly running car. But at the same time, they say it can't be detected by a tech 2 scanner.... and if it can't be detected by a tech 2, i doubt you would be able to see it.
hmmm it has to be so complicated. Well it runs the exact same ****ty way when i unplug the maf
