Thread: l67 bottom end with l36 heads, intake, and pcm?
Results 1 to 9 of 9
  1. #1 l67 bottom end with l36 heads, intake, and pcm?
    SE Level Member ActionMatt's Avatar
    Feb 2010
    Maryland
    I'm going to be putting a series 2 into my Oldsmobile with plans to go turbo soon after. I was wondering if i could use the L67 block (for the lower compression when i go turbo) with L36 heads, intake, and stock pcm. I know they'll fit, but would the lower compression effect the pcm? Of course ill be tuning the pcm after the turbo setup, but i was wondering if i could avoid the hassles of tuning while i get the engine up and running.
  2. #2 Re: l67 bottom end with l36 heads, intake, and pcm?
    I don't see why it wouldn't be a happy camper with L36 timing and much lower compression. It'll probably be gutless compared to the L36, but that's only til you turbo.
  3. #3 Re: l67 bottom end with l36 heads, intake, and pcm?
    be prepared to be slow.
    other than that itll all work fine.
  4. #4 Re: l67 bottom end with l36 heads, intake, and pcm?
    Slower than 16's slow
  5. #5 Re: l67 bottom end with l36 heads, intake, and pcm?
    Apr 2009
    stockton ca
    slow till turbo
  6. #6 Re: l67 bottom end with l36 heads, intake, and pcm?
    Ya...12's slow.
  7. #7 Re: l67 bottom end with l36 heads, intake, and pcm?
    It's interesting you posted this. I was considering something similar. Should be getting a turbo soon myself. Meanwhile I'm cruising an 00 GS. Thought I could prep for the future and get the leaky rear valve cover done at the same time. Because clearly changing a vc gasket includes a LIM gasket swap while the coolant is drained and the hoses are being replaced. Which probably leads to the 1.9's, springs etc going on. I considered it and didn't pull the trigger as the turbo guy isn't as communicative as I'd like and it's been too long.
  8. #8 Re: l67 bottom end with l36 heads, intake, and pcm?
    Feb 2010
    Maryland
    Thanks for all your input.
  9. #9 Re: l67 bottom end with l36 heads, intake, and pcm?
    Except me. My input blew. HA
  1. bottom swap, or how i learned to rebuild the bottom end completely
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-18-2009, 03:37 AM
  2. Out The Top or Through The Bottom
    By SyntheticShield in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-20-2008, 01:07 PM
