Thread: P0420 code! WHATTT
Results 1 to 14 of 14
  1. #1 P0420 code! WHATTT
    Florida
    For a few months now my check engine light has been on.I had a head job done back in may due to the infamous coolant leaking into the heads.Since then I have noticed a problem getting slighty worse by the weeks.when I start up my car it idles crappy until its warmed up. Then if I step on it at about 2-3 gear or 50-60mph it starts hesitating and jerking for more speed.Always happens.Seems to happen faster and worse when the car is hotter.I had the code read a few weeks ago and it was p0420.I changed my cat.im thinking either o2 sensor or fuel filter.Any ideas?
  2. #2 Re: P0420 code! WHATTT
    SE Level Member grandprix85's Avatar
    Milwaukee, WI
    Check your MAF. I had the same symptoms with my car. I replaced my MAF and it stopped.
  3. #3 Re: P0420 code! WHATTT
    Donating Users ls6velless454's Avatar
    Nov 2009
    Portage, IN
    Usually that code it related to your gas cap being bad/evap system it could even be a bad purge solenoid or vacuum line off the engine.
    There is no replacement for displacement........unless you have a supercharger or turbo
    2000 Bright Red GTP Coupe GXP axle back, GMPP sway bar, NGK TR6, 180 stat. (Uninstalled Aeroforce Interceptor, DHP PCM, FWI, Gen V on the way) and still no pulley in sight.
  4. #4 Re: P0420 code! WHATTT
    Florida
    hmmm.those sound like possibilities especially the MAF.I'll see try those if the problem still persists.thanks guys
  5. #5 Re: P0420 code! WHATTT
    Florida
    Oh also when I got the code scanned it specifically said catalytic inefficiency/bank 1 or something like that.Not sure if that makes a difference.
  6. #6 Re: P0420 code! WHATTT
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    p0420 is Cat code, Rear 02 issue. Replacing the maf will do nothing.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  7. #7 Re: P0420 code! WHATTT
    Florida
    The 1st thing i thought of after my new cat,the rear 02 sensor.thanks man
  8. #8 Re: P0420 code! WHATTT
    SE Level Member Echo1999's Avatar
    Nov 2008
    Washington State
    I just had a P0420, it means it is time to replace the CAT. It also means that both of your sensors, before CAT and after CAT are working fine.
    I had a "heavy metal" CAT from flowmaster installed, the shop cleared the code and it has not come back. Cost me $285.00
  9. #9 Re: P0420 code! WHATTT
    Florida
    i got a magnaflow high flow cat already.code still there.i also have a mis in cylinder 1,or p0301
  10. #10 Re: P0420 code! WHATTT
    Jul 2008
    sumter,south carolina
    plugs? wires? ICM? coils?
    02 GTP with mods 05 GP for DD
  11. #11 Re: P0420 code! WHATTT
    Nov 2008
    Washington State
    Time to suspect that it could be a bad PCM.
  12. #12 Re: P0420 code! WHATTT
    Jul 2008
    Quote Originally Posted by Echo1999 View Post
    how so? theres alot of other things it may be.. could be a ****ty gasket job and coolant is making its way to a cylinder.
  13. #13 Re: P0420 code! WHATTT
    Florida
    nope guys.the mis was a simple fix.my spark plug heat sheild was sparking with a bolt which pulled from the spark plug itself causing the mis.lol.i just took it off and it pulls hard again with no mis.back to the p0420 code,would a bad 02 sensor cause the engine idle to surge a little when accelerating?
  14. #14 Re: P0420 code! WHATTT
    Apr 2009
    stockton ca
    A highflow cat can kick a 420 code rear o2 can kick a 420 code and so on
    high flows arent as efficient as standard cats so it will still kick the code on some cars
    Also depends how your tune is to test sscan your rear o2 sensor it should stay steady under 400 mili volts
    if its higher or bouncing around thats your issue
  1. P0420 code
    By BChimo in forum General Tech Discussion
    Last Post: 10-18-2012, 12:18 PM
  2. P0420 code and white on manifolds...
    By dcwright02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-15-2010, 08:22 AM
  3. P0420 code
    By Madness in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-31-2010, 03:25 PM
  4. p0420 code, which o2 sensor do i replace?
    By Golman76 in forum General Tech Discussion
    Last Post: 02-15-2010, 10:50 PM
  5. p0420 code on
    By fst in forum General Tech Discussion
    Last Post: 01-05-2008, 04:19 PM
