Thread: Chirping noise coming from altenator/tensioner only when cold.
Results 1 to 4 of 4
  1. #1 Chirping noise coming from altenator/tensioner only when cold.
    SE Level Member Beauty026201's Avatar
    Jun 2010
    Cape Cod, MA
    So my car has recently developed a chirp..It only seems to occur first thing in morning or after sitting for 6 or so hours. It's coming from the Alternator/Tensioner area, can't tell which yet..The chirp goes away after the engine has been running a few minutes and doesn't return the rest of day if I'm using the car. Also, if I drive it cold while chirping the noise will increase or decrease with engine speed until it eventually " fades " when engine warms to normal temp. My first thought was a bearing in Alternator, but I'm thinking if that were the case it would do it all the time, same for tensioner...I haven't really inspected belt because it's fairly new. Any thoughts would be greatly appreciated...as it is a little annoying, especially at 6:30 in the morning...the chirp just echo's threw the land.
  2. #2 Re: Chirping noise coming from altenator/tensioner only when cold.
    GTX Level Member cerick08GP's Avatar
    Hehe, I doubt it is your belt. If the belt is in good repair with anything even close the correct tension you should be golden there. The chirp indicates something is momentarily locked up, hence causing the belt to slip. That something could be any of the components. The only way to know is to take off the belt and check every component. Check for smooth rotation, end play, pulley condition, and any obvious damage. The problem in these type cases is usually obvious, or it will be in time when the component finally fails.
    Like I mentioned it is really impossible to tell these things for sure without a little hands on, but my pure guess would be the water pump.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  3. #3 Re: Chirping noise coming from altenator/tensioner only when cold.
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    or just buy one of these for cheap as hell.... it definitely wont be the last time you use it either
    Mechanic's Stethoscope
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  4. #4 Re: Chirping noise coming from altenator/tensioner only when cold.
    Jun 2010
    Cape Cod, MA
    To my surprise it was the belt...everything else checked out. Replaced the belt, chirping is gone
  1. Noise coming from steering wheel????
    By jmack98 in forum General Tech Discussion
    Last Post: 04-26-2011, 05:41 PM
  2. Whining noise coming from alternator maybe?
    By Lionel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-28-2010, 11:50 PM
  3. Chirping Noise
    By TeeWX in forum General Tech Discussion
    Last Post: 09-02-2009, 07:29 PM
  4. odd noise coming from front wheels
    By pontiacgp759 in forum General Tech Discussion
    Last Post: 04-15-2009, 09:32 PM
  5. weird noise coming from engine
    By q1w2e3r4t5 in forum General Tech Discussion
    Last Post: 04-02-2009, 09:59 PM
