Thread: Haaalp! Persistent P0420 Code :(
Results 1 to 9 of 9
  1. #1 Haaalp! Persistent P0420 Code :(
    St Louis Metro-East
    '05 GP Base, 3800 series 3 N/A, no options. Seriously. Not even anti-lock brakes.
    P0420 - Catalyst efficiency below threshold, bank 1.
    Brand new cat.
    Upstream/Downstream o2's
    cleaned out the top end (sea foam) with the old cat installed...
    What am I missing? This is driving me nuts, and $500 invested...well, hell, that could've been performance mods. Instead of that, I've been plagued by this code since I got the car. Before I go nuts and start replacing EVERYTHING....I have to come here.
    Wow me with your knowledge, GPforums. I'll love you forever if you can help me get this fixed!
  2. #2 Re: Haaalp! Persistent P0420 Code :(
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    get a tuned pcm withe the 420 code deleted my car does the same thing after i changed the cat cause i have a high flow cat
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  3. #3 Re: Haaalp! Persistent P0420 Code :(
    the only way for it to be doing that with all the new stuff you said you replaced is if the car is running mega ass rich so that the cat doesnt even have a chance to catch all the junk. either that or you bought a DOA o2 sensor.
  4. #4 Re: Haaalp! Persistent P0420 Code :(
    Charles City, IA
    Also some aftermarket cats, not even highflow ones can still set the code if not installed correctly or are cheapos.
    SMGPFC Two Nipple General
  5. #5 Re: Haaalp! Persistent P0420 Code :(
    Pennsylvania
    I'm gonna just throw this out there because I'm out of my mind:
    Unplug the positive from the battery overnight.
  6. #6 Re: Haaalp! Persistent P0420 Code :(
    GTX Level Member Biohazed's Avatar
    Philadelphia, Pennsylvania, United States
    I get the same thing on my car started last week just installed a ZZP Downpipe with cat and a New o2...
    *image too tall*
    BMR F + R Strut Bars - Falken Torque V 18's - JVC S900 - Kicker C10's - Spyder Projectors, Wizaird,
  7. #7 Re: Haaalp! Persistent P0420 Code :(
    St Louis Metro-East
    Thanks for all the suggestions, guys. If the batt disconnect doesn't work (permanently) then I'm going to get a PCM...if I can afford one. The price of the computer doesn't get me it's the damn core charge!
  8. #8 Re: Haaalp! Persistent P0420 Code :(
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    If you get a new CAT, it's gonna throw the code. Did it on my Imp and Grand Prix. Try to find someone local with a tuner who can disable the code, otherwise you're need to get a tuned PCM.
    Battery disconnect will work for 3 restarts; the code will return. And a code reader that allows a code delete will just work for 3 restarts as well.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  9. #9 Re: Haaalp! Persistent P0420 Code :(
    St Louis Metro-East
    Quote Originally Posted by Deezul_AwT View Post
    Thanks for the info, bro. Yeah, I'm probably going to hunt down a custom PCM... I'm moving someplace far far closer to work so I won't have to worry so much about using expensive gas every day.
    So is with GM making it so you have to buy OE replacements instead of just grabbing a weld-on for 50 bucks? That's bogus.
  1. P0420 code
    By BChimo in forum General Tech Discussion
    Last Post: 10-18-2012, 12:18 PM
  2. P0420 code and white on manifolds...
    By dcwright02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-15-2010, 08:22 AM
  3. P0420 code
    By Madness in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-31-2010, 03:25 PM
  4. P0420 Code keeps setting on 2001 GTP
    By Littlegiant in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2008, 07:50 PM
  5. p0420 code on
    By fst in forum General Tech Discussion
    Last Post: 01-05-2008, 04:19 PM
