Thread: ssm90
Results 1 to 5 of 5
  1. #1 ssm90
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    ok do u guy think these mod are ok for this pully
    3.8 plog 2.5 catted dp cone filter canned tune ported s/c l67 injectors
    3.4 headers 1.84 rr tune cone filter gtp injectors ported s/c l67 tb
    3.25 same as above but with ssic
    thanks
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  2. #2 Re: ssm90
    no, your compression is too high. youre gonna need setup 2 for the 3.8 pulley and setup 3 for a 3.4.
  3. #3 Re: ssm90
    May 2008
    staten island,NY
    i ran the 2.5 dp and plog with my 3.4 for the longest time and it was fine, although headers are cheap enough now, like the speed daddy guys on ebay. you cant run smaller than a 3.4 with the SSM90 pulleys unless you machine the snout. i would change to a GTP pulley set up like i did to my car, call up morad he has everything you will need and it shouldnt be more than $100. dont swap pulleys because you want boost, this blower isnt a compressor like a whipple or a kenne bell. an L36 block with a 3.4, rockers, headers and a good tune will be a quick car.
  4. #4 Re: ssm90
    ok thanks for the replys i was just wanting to know because i want to get to mid 13s then im done
    sold 97 GTP stock
  5. #5 Re: ssm90
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    I run a 3.5 with my mods and I can guarantee I will knock with a 3.4. SS m90 goes to a 3.25 pulley. Dont think you need to turn down the snout to run it either. I wouldnt run under a 3.6 on plog IMO
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  1. Top Swap/SSM90
    By 01gtspecial in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-02-2009, 12:13 PM
  2. Top Swap vs SSm90
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-14-2009, 07:06 PM
