Thread: Misfire, Stumble
Results 1 to 11 of 11
  1. #1 Misfire, Stumble
    Missouri
    I have a 2000 GT. It starts just fine but when you go from a stop it stumbles. It stumbles until it gets up to about 45. Runs fine after that. Going up inclines it lacks power and stumbles a lot. The SES light comes on and flashes then goes off. It is on now, the code is P300. I've looked over everything, nothing seems to be wrong on the surface. I've got new plugs and wires I'm putting on. Recently changed the air filter, fuel filter, and pcv valve. Scratching my head.
  2. #2 Re: Misfire, Stumble
    Pennsylvania
    How's the idle? Frm what I can tell, that's funky/vague to diagnose. Maybe a Tech2 can get some more info. Some easy suggestions that are just good to do anyway: Clean MAF, clean throttlebody, new throttlebody gasket, run a bottle of GM fuel system treatment...
  3. #3 Re: Misfire, Stumble
    New Jersey
    p0300 is a random misfire and the check engine light blinking means catalyst damaging misfire. just change the plugs/ wires and youll be good.
  4. #4 Re: Misfire, Stumble
    Missouri
    It idles fine, but at times will stumble or surge. When I turn on the a/c it gets worse. I cleaned the MAF a couple weeks ago.
  5. #5 Re: Misfire, Stumble
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    check wires/plugs/plug gap/ and you may want to get your ICM tested
  6. #6 Re: Misfire, Stumble
    New Jersey
    because the a/c is putting a bigger load on the engine. if you have new plugs and wires put them in.
  7. #7 Re: Misfire, Stumble
    Missouri
    I am changing plugs and wires this weekend. Also testing ICM and coils. Thanks for all the advice and help.
  8. #8 Re: Misfire, Stumble
    Missouri
    Well I changed plugs and wires. It still was the same. I had the ICM checked. That was it. Repalced it and the coils. Runs real good. Thanks for all the help.
  9. #9 Re: Misfire, Stumble
    PA
    Quote Originally Posted by Bill3256 View Post
    Just curious, how do you test the ICM? Is this something you need special equipment for?
    98 GT stock
  10. #10 Re: Misfire, Stumble
    GT Level Member clevelandfan's Avatar
    ohio
    sorry i was late on this, but i was gonna say icm, or coils right away. i had this happen a couple times at work, seeing as i work at advance auto. guess its not that uncommon to go on these motors
    97' Grand Prix. Blurring the lines between SE, and GT
  11. #11 Re: Misfire, Stumble
    New Jersey
    ah stupid ignition module. good to see you got it fixed.
  1. Hesitation and Stumble
    By Bill3256 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-08-2010, 06:54 PM
  2. Power loss / slight stumble @ WOT
    By Wilford in forum General Tech Discussion
    Last Post: 10-25-2009, 08:05 AM
  3. Engine Stumble
    By briggsracing23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-25-2009, 09:02 AM
  4. Rough Idle/Stumble after LIM Install
    By hesersypb in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2009, 08:27 AM
  5. Stumble at idle
    By lowdeuce in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-21-2008, 10:26 PM
