Thread: Top Swapping I have questions.
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 21 to 40 of 110
  1. #1 Re: Top Swapping I have questions.
    Kansas
    Quote Originally Posted by 99prixgt View Post
    i hit 13* of knock on a 3.6 and 14* of wot timing
    my setup- headers/1.9/N*
    stick with the stock pulley and start with stock gtp bin and go from there. Definitly get a wideband and a tuner or you will be wasting alot of your time trying to tune your car n/b and still not get anywhere. I recommend a dhp
    Im going to have brian tune my **** and I'm pretty sure he knows what he is doing. Going to go get gaskets and a Wideband today then order my headers and aeroforce.
    SOLD 1999 GT Silvermist TS
  2. #2 Re: Top Swapping I have questions.
    Bastard Reptile's Avatar
    Kansas City, MO
    Quote Originally Posted by Gafford44 View Post
    I've got a wideband that I tune with, you just need to keep the stock rear O2 bung in.
    And if you need ANY more gaskets and want them GM, hit me up, I work at a dealer, remember?
    I'm almost home, staying in STL for the evening, and then I'll be back on Monday if you wanna meet up.
  3. #3 Re: Top Swapping I have questions.
    Kansas
    Quote Originally Posted by Reptile View Post
    Wait a second. Can you get those gaskets less then 200? Like do you receive a discount? I'd imagine so. Oh and yes monday ill be bring my stuff down.. I want you too look at my Blower I have some questions on its condition.
  4. #4 Re: Top Swapping I have questions.
    Kansas City, MO
    You're basically needing a whole upper gasket set, correct?
    Heads, LIM, Valve Covers, o-rings, and then SC? I should be able to get it for quite a bit less than 200, but again, I'll have to wait until I can look it up at work. I'm thinking in the $160 range for it all. You'll have to get head studs somewhere like ZZP though, I can't get them for near the price they sell. Although I really have nothing against the stock TTY bolts honestly.
  5. #5 Re: Top Swapping I have questions.
    Kansas
    Well this is what I was told i needed plus you've done the swap you should know right
    Quote Originally Posted by kfish View Post
    2 head gaskets
    Intake gasket set
    Plenum gasket set (if you ask for a supercharger gasket they look at you funny)
    TB gasket
    Fuel injector o rings (you need 2 boxes)
    Head bolts
    Coolant elbows
    Plus valve cover gaskets
  6. #6 Re: Top Swapping I have questions.
    Brian's done a top swap before?
  7. #7 Re: Top Swapping I have questions.
    Kansas
    maybe a couple in this life
  8. #8 Re: Top Swapping I have questions.
    Kansas
    Ok so i ordered my aeroforce, boost and oil press gauge, gauge pod, and all my gaskets yesterday. Today I ordered my speed daddy headers. What size clamps should i get and how many?
  9. #9 Re: Top Swapping I have questions.
    Donating Users kfish's Avatar
    Ohio
    you need 2 3" clamps for downpipe. and 2 2 1/4" clamps for the crossover, and a tube of copper rtv.
  10. #10 Re: Top Swapping I have questions.
    SE Level Member dbrincefield's Avatar
    Feb 2010
    Dayton
    hey man i just finally got done doing a top swap on my car and as of now i have a successful top swap, speed daddy headers, 4" fenderwell intake, custom street tune, and a 3.4" pulley. with the right tune you'll be able to get a smaller pulley on there with no problems but make sure you get those headers on before you try to drop sizes!!!! and also i had fouled my spark plugs with ac delco 103's and i was told to go to platinum 104's and havent had any problem since!!!..enjoy it man...its a blast to finally have some boost!!...lol...oh and i did mine on an 03 Monte Carlo not a grand prix but basically the exact same minus body style!!
  11. #11 Re: Top Swapping I have questions.
    Kansas
    Quote Originally Posted by dbrincefield View Post
    Yea i got the headers they are going on asap and I don't think im dropping pulleys yet so i dont throw more money into my car. Ill probably drop after a month or so of driving if i can get a deal on a MPS
  12. #12 Re: Top Swapping I have questions.
    so you're running like 10* of timing? or you're just lucky
  13. #13 Re: Top Swapping I have questions.
    Feb 2010
    Dayton
    well when i first got everything hooked up just top swap wise with the standard 3.8 it was running horrible and it was slower than any car out there...it took like a minute just to get to 60 and i was throwin all sorts of codes...come to find out the pcm was all messed up originially and i had even sent it away to get a mail tune from 3800 performance but it was runnning like 19* of timing....i dont know if you guys know of a guy named tim who used to work for intense racing but he now works at a place in dayton ohio called TKO performance...he took it and made it so it was running right along with installing some headers and he said it would be safe to drop pulley size so i got a 3.5 inch pulley and he didnt have a hub that would fit it so he just put on a 3.4 pulley and did all the tuning afterwards...i'm thinking he said i'm running like 12-15 degrees of timing but dont mark my words!!!...it's quick...thats all i know...lol
  14. #14 Re: Top Swapping I have questions.
    15 isn't bad since thats 16* because your cam is one degree advanced, but less than that is bad.
    And you really shouldnt have driven your car with a top swap without a proper tune.
  15. #15 Re: Top Swapping I have questions.
    Feb 2010
    Dayton
    oh yeah trust me i know...but 3800 performance programmed their "top swap" setup onto the PCM and it was supposed to be able to run right.......but it didnt...after i realized it was completely messed up and not running right, i took it to a shop and he got it in as soon as he could which was like a week later....it ran pretty good as long as you stayed out of the throttle...also when it wasnt running right, i was lucky enough to not have any engine knock...it was just a messed up situation!!! but its fixed now!! I got a race against a mustang fox body that runs a 13.5 on drag radials but we're doin it on the street...lol i've been told i should be able to take him but i guess we'll see!!
  16. #16 Re: Top Swapping I have questions.
    LOL no, you might run high 13's.
  17. #17 Re: Top Swapping I have questions.
    Kansas
    Its about to be christmas in the gafford house hold
  18. #18 Re: Top Swapping I have questions.
    Headers? When are you doing the Top Swap?
  19. #19 Re: Top Swapping I have questions.
    Kansas
    Is that headers to me? Mine are on their way. And once i decide where im going to do the swap.
  20. #20 Re: Top Swapping I have questions.
    Feb 2010
    Dayton
    ur prolly right...but as long as he sits there and spins i'm game with that!!..and besides thats a **** ton better than the like 15.4 i used to run before i did the swap!!!
  1. Swapping '03 radio for '04-'08
    By rpenling in forum Audio, Security & Visual Electronics
    Last Post: 03-21-2010, 10:28 PM
  2. Questions on swapping parts
    By mscally07 in forum Audio, Security & Visual Electronics
    Last Post: 08-07-2009, 12:59 AM
  3. Swapping engines
    By dbz09 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-06-2009, 12:51 PM
  4. Swapping PCM's
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2009, 09:34 PM
  5. Swapping Engine
    By Redgtp1999 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2008, 08:06 PM
