i was wondering if anyone knew if there is a rebuild kit or what parts should be replaced when rebuilding a 3.8. the engine has 193K on it and I'd like to make it like new. any help would be great
I'd start with water pump.ps pump,all gaskets, lifters, thats just a couple things. I guess it really depends on how far into the engine you want to go.
Basically replace anything that can wear so any and all bearings or parts that wear like o-rings, main bearings, lifters, pushrods, valve springs, valve seals, water pump, P/S pump, idler pulleys, tensioners etc.
Depends what you are looking to spend
if your going to do a full rebuild your looking at around 2000 thats with machining all gaskets, new pistons, check crank shaft tru it up and polish as well as cam
new oil pump, new timing set,bearings,rings,head bolts,new lifters, Head work magna flux,valve job, check all rockers/rods
And thats with you doing all assembly most machine shops will build the bottom end though around here the charge 400 extra
then add on a new alt/power sterring/water pump
or you could find a low mileage short block have your heads checked/valve job and new wtr pmp/alt/pwr str all pulleys and tensioners
for around 1200
