Thread: Spark Plug question
Results 1 to 9 of 9
  1. #1 Spark Plug question
    Jul 2008
    Atlanta Georgia
    Hey guys i am looking at changing my spark plugs, and i have been reading about a bunch of people talking about bring there KR down. What is KR. What kind of plugs would give me the best lap time. I heard the autolite 103's work the best but i cant find them anywhere, any suggestions?
  2. #2 Re: Spark Plug question
    Outer Space
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: Spark Plug question
    Troy OH
    KR is knock retard. it's explanation is a physics lesson:
    a gas's pressure, volume, and temperature are all related. what causes KR is as the piston compresses the gas, the volume decreases, causing the temperature and pressure to increase. now, gases have a certain temperature that cause them to ignite and combust without a spark. this temperature is reached easily if the car is not properly tuned, i.e. too much air/fuel mixture, which is why dropping a pulley size with no other mods will blow your motor. this isn't supposed to be the case, which is why a spark plug is necessary. the spark plug is set up to ignite the compressed air/fuel mixture at precisely the right time for max performance, which is right at (or fractions of a second after) top dead center. if the gas combusts prior to TDC, the explosion will force the piston downward while the crankshaft is still pushing the piston up. if severe enough, you will chip pistons, etc...
    the reason guys change out their plugs is because some plugs run at a cooler heat range, not letting the motor get to a high enough temperature for KR to happen. they're often used with a cooler thermostat and intake/exhaust mods to help drop a pulley size and get into other modding. if you're not modded, you won't see improvements from a cooler plug, and might actually see a decrease in performance. it's really the same concept as intercooling or methanol/water injection, just on a much smaller scale.
    this thread also helps:
    http://www.grandprixforums.net/f81/s...car-17482.html
    Last edited by Poil336; 04-12-2010 at 06:45 PM. Reason: camshaft and crankshaft are not the same thing
  4. #4 Re: Spark Plug question
    Troy OH
    sh!t, beat me to it lol
  5. #5 Re: Spark Plug question
    Jul 2008
    Atlanta Georgia
    Well i do have a 4 inch cold air intake, exhaust upgrades, msd wires, and i am running a 180 drilled thermostat. Well which kind of plugs would you suggest?
  6. #6 Re: Spark Plug question
    Willoughby, Ohio
    this might help too, just to add to poil's nice explanation...
    http://www.grandprixforums.net/f18/w...here-1507.html
  7. #7 Re: Spark Plug question
    Troy OH
    unless your exhaust is smaller than stock, you won't be generating more heat, so the stock heat range is what you want. Autolite 606's are what i replaced mine with. not sure about anything else, but you don't need to go find anything special.
    Quote Originally Posted by CTKGP09 View Post
    http://www.grandprixforums.net/f18/what-is-octane-kr-explained-here-1507.html
    I'm gonna learn where that one is too lol. i honestly thought it would be easier to type an explanation that to find that one. really good write-up though.
  8. #8 Re: Spark Plug question
    Autolite 104's are for a basic 3.4" setup...the trick is you want the HOTTEST plug that you can GET AWAY with...withOUT knocking. A good N/A plug is the Autolite 606 or NGK TR55...I say copper AL606 because these cars love copper plugs.
  9. #9 Re: Spark Plug question
    Troy OH
    my bad, i have the 606's. don't know what i was thinking
    post edited/fixed
  1. Spark Plug Question.
    By DnaProdigy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2011, 09:45 PM
  2. Spark Plug Help
    By STP5593 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2010, 10:15 PM
  3. Spark Plug Heat Range Question
    By Agentlongwood in forum General Tech Discussion
    Last Post: 11-09-2009, 03:25 PM
  4. Corolla spark plug wire change (general maint. question)
    By 04CompG in forum Off Topic Discussion
    Last Post: 09-16-2008, 03:21 PM
  5. Spark plug question
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2008, 05:36 PM
