Thread: Need help with fuel lines
Results 1 to 5 of 5
  1. #1 Re: Need help with fuel lines
    Apr 2011
    Elk Rapids, Michigan
    I had the opposite problem! Thanks to Michigan winters and the love of salt on the roads I couldn't get my fuel filter off. I ended up replacing the complete fuel line. I had it the next day from the local GM dealer and it cost around $110. That part may be one benefit of living down the road from GM. It was a chore to get in but it has a newer style quick disconnect at the fuel rail. No leaks thank goodness. I cut off the old connector and I'd gladly mail it to you if it would help. I'm probably gong to convert to braided stainless steel lines with AN-6 fittings but that will be at my top swap or the L67 I'm building(long term project)
  1. Fuel Lines O rings
    By BDEGhost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-05-2010, 08:45 PM
  2. Rusted fuel lines!
    By foursixer in forum General Tech Discussion
    Last Post: 01-28-2010, 03:58 PM
  3. Cutting fuel lines
    By Sabrewings in forum General Tech Discussion
    Last Post: 06-26-2009, 12:14 AM
  4. SS fuel Lines
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2008, 01:02 AM
