Thread: Plog vs PEM or Ported TB vs HVTB
Results 1 to 15 of 15
  1. #1 Plog vs PEM or Ported TB vs HVTB
    Erie, PA
    Are there huge gains with buying a plog and not a pem or a zzp HVTB and not a ported TB with the mods I plain on getting (( 2.5 dp(magflo cat + U-bend delete), PEM -Rockers(ER's) + HV3, 180 T-stat, TB, Aftermarket PCM or Tune)) I dont know if I should spend a lot of money in purchasing new mods or if I can just buy, for an example a PEM on a classifed section for one-fourths the amount of money (ex. plog=$120, used PEM=$35) So basically all Im asking "is it worth it".
    Thanks,
    Bobby
    99 GP GT coupe on Chrome 18's with a K&N air intake
    R.I.P. Firefighter Michael D. Crotty whom anwsered his last alarm on April 8, 2008
  2. #2 Re: Plog vs PEM or Ported TB vs HVTB
    Barksdale AFB, LA
    The problem with PEMs is that the shared area for all the front cylinders is so small, and can't be ported. That's why the Plog was created.
    The HVTB is a ported TB.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Plog vs PEM or Ported TB vs HVTB
    SE Level Member Grandprixboy1224's Avatar
    Lapeer
    i would do my list for a gt like this:
    -Plog
    -2.5 Dp High Flow Cat
    -HV3
    -HVTb
    -Rockers
    -zzp 1.0pcm
    -180* T-Stat
    or if you had the money just get a top swap. with all that your looking at $1050 when a top swap at zzp cost like 1500.
    2000GP-GT|CC|8%tint|Exhaust DRT|CAI| Ordering KV5 and 10000k HID.
  4. #4 Re: Plog vs PEM or Ported TB vs HVTB
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    I can't ever get much of a straight reply regarding the HV3 and a ported TB. I don't intend to race my GP but to use it as my daily driver and more or less maintain the same speed. Plus, what I have read says the HV3 and ported TB only return gains at higher RPMs. Since I only have CAI now, and will be adding a Plog and new downpipe over the next few months, I want to know if it's really worth shelling out the money for that right now. My Impala is my performance car, so I don't need the speed out of the GP.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  5. #5 Re: Plog vs PEM or Ported TB vs HVTB
    Barksdale AFB, LA
    The HV3 is going to show the most improvement in higher RPMs. So, to really support that, you will want some good mods along with it. HVTB, Plog, 2.5" DP, and intake. Then, a PCM so that you can actually rev to the RPMs where it makes the most difference.
    If I remember right, it added like 10 peak WHP, but at like 6k RPM it added 30WHP. I think the L36 usually peaks around 5200 RPM, so you would want the higher RPMs to make use of what else it's giving you. Pair all of that with some ER rockers and that thing would haul some ass that might make you wonder where the whine is.
  6. #6 Re: Plog vs PEM or Ported TB vs HVTB
    Feb 2008
    Cumming GA
    Ok, that's given me a better idea. At this point, it's a backburner item. Despite having the UIM replaced and the ease that would be for dropping the HV3 in, it means also getting TB, PCM, rockers, etc. So that simple "$200" HV3 = another $800 in accessory mods. I'd just assume change the TB and rockers on my Imp.
    With a 100 mile round trip commute currently, and 88K on an 8 year old car, I don't want to drop in several hundred into a car to upgrade its performance that will either die on me or get swapped for something else. It's possible in a few months my commute could drop to 30 miles round trip, and then I might go crazy on the Imp AND the GP. Still won't do a top swap or turbo though, as much fun as that would be.
  7. #7 Re: Plog vs PEM or Ported TB vs HVTB
    Barksdale AFB, LA
    If I were you, I'd go with a Plog, ZZP 2.5" DP, and some sort of intake. Good for the DD, and takes care of a possible cat issue.
  8. #8 Re: Plog vs PEM or Ported TB vs HVTB
    GT Level Member rodman's Avatar
    Apr 2008
    hv3 and hvtb are???
  9. #9 Re: Plog vs PEM or Ported TB vs HVTB
    Feb 2008
    Cumming GA
    Quote Originally Posted by Sabrewings View Post
    Agreed. K&N CAI already on my GP, just ordered the DP today, and once I return my old cat and get my $50 credit, I'll be ordering the Plog!
  10. #10 Re: Plog vs PEM or Ported TB vs HVTB
    GT Level Member GP2003GT's Avatar
    Fayetteville, NY
    yeah i ordered the HV3 and soon i will order the HVTB and ER rockers to go with it, i cant wait!!! i already have a 3inch full cat from zzp and an intake, i just cant wait to combine all of these together, dont worry ill let you all know how it goes...lol
    http://www.cardomain.com/ride/2556536 NKG Iridium Plugs, 8mm Spiro Wires, ZZP Reprogrammed PCM, ZZP 3" full cat, ZZP Ceramic Coated Ported Manifolds, ZZP HV3, ZZP HVTB, ZZP ER Ratio Rocker Arms, ZZP Drilled 180* Thermostat, MotorSports Performance Intake, Reptile's IAT and dezldave tuned
  11. #11 Re: Plog vs PEM or Ported TB vs HVTB
    Barksdale AFB, LA
    Quote Originally Posted by rodman View Post
    hv3 and hvtb are???
    HV3 is an upper intake insert from ZZP. HVTB is ZZP's ported throttle body.
    Quote Originally Posted by GP2003GT View Post
    We just had a member finish all this on his car, and he's been ecstatic. You will enjoy the difference!
  12. #12 Re: Plog vs PEM or Ported TB vs HVTB
    Fayetteville, NY
    cant wait!! ^^
  13. #13 Re: Plog vs PEM or Ported TB vs HVTB
    Apr 2008
    Thanks for answering and neither one apply to series 3
  14. #14 Re: Plog vs PEM or Ported TB vs HVTB
    Barksdale AFB, LA
    I don't think we said they did.
  15. #15 Re: Plog vs PEM or Ported TB vs HVTB
    Apr 2008
    No you didn't
    I was saying simply that i guess this stuff doesnt apply to me is all...
    I was wrong wil's hooking me up with hv3....
  1. Pics of Plog plz :-)
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-12-2008, 09:13 PM
  2. Ported LIM?
    By Sabrewings in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2008, 03:02 AM
