Thread: P0420 code
Results 1 to 3 of 3
  1. #1 Re: P0420 code
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    Code P0420 means "Catalyst System Efficency Below Threshold (Bank 1)"
    P0420 is actually Catalyst System Efficiency Below ThresholdCatalyst System Efficiency Below Threshold.
    This means that the secondary O2 sensor detects that the catalytic converter isn't working as efficiently as it should.
    This engine code can be triggered by any one of the following:
    1.) The catalyst in the catalytic converter is cracked, clogged, or otherwise damaged.
    2.) The secondary O2 sensor is malfunctioning.
    3.) There is an exhaust leak.
    4.) The computer unit is faulty.
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  1. P0420 code
    By BChimo in forum General Tech Discussion
    Last Post: 10-18-2012, 12:18 PM
  2. p0420 code, which o2 sensor do i replace?
    By Golman76 in forum General Tech Discussion
    Last Post: 02-15-2010, 10:50 PM
  3. If i delete the rear 02sensor code(p0420)
    By kinglou10 in forum PCM Tuning
    Last Post: 07-02-2009, 05:22 PM
  4. P0420 Code keeps setting on 2001 GTP
    By Littlegiant in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2008, 07:50 PM
  5. p0420 code on
    By fst in forum General Tech Discussion
    Last Post: 01-05-2008, 04:19 PM
