Thread: Check engine code: P0300?
Results 1 to 6 of 6
  1. #1 Check engine code: P0300?
    SE Level Member CSteen85's Avatar
    Long Island, NY
    So, I was just about to get down and dirty and start doing some of own small repairs. I even took off the tail light and replaced the bulb, by myself.
    Then... my check engine light went on. I had sort of a rough start and then I noticed the light .
    I went straight to Auto Zone (my 2nd time today) and they ran the scanner for me for free. It gave code P0300 and the printout they gave me said:
    CYLINDER MISFIRE DETECTED - RANDOM CYLINDERS
    EXPLANATION:
    THE POWERTRAIN CONTROL MODULE MONITORS THE CRANKSHAFT SPEED AND HAS DETECTED A MISFIRE CONDITION.
    PROBABLE CAUSE:
    1- IGNITION SYSTEM FAULT - SPARK PLUG(S), IGNITION WIRES, COIL
    2- VACUUM LEAK
    3- INJECTOR FAULT
    4- HIGH OR LOW FUEL PRESSURE
    I KNOW I am leaking some oil (the mechanic told me) and he recommended I replace the valve cover gaskets as well as intake manifold gaskets. He also recommended I replace my upper and lower radiator hoses (which I was going to do before the engine light went on).
    My question is, how do I figure out which of these things it is? I don't know how to do ANYTHING. I google everything to try to figure out directions, but I'm trying to get a friend to do some of the work for me. Will fixing any of the things I already knew needed to be replaced get rid of this light?
    I'm so scared to drive the car now that the check engine light is on.
    Can anyone help me figure this out?
    Thanks,
    C
    1997 Grand Prix SE, 3.8L V6 SFI, 140k, purchased on 3/6/10.
  2. #2 Re: Check engine code: P0300?
    Charles City, IA
    Start with plugs and wires.
    SMGPFC Two Nipple General
  3. #3 Re: Check engine code: P0300?
    SE Level Member whodat79's Avatar
    neenah
    just like 01 gtp said. find out what the ohms should be on coils. and do the same for the wire but move the wires around a bit to check for breaks in the leads. thats a start
    2000 GP GTP....
  4. #4 Re: Check engine code: P0300?
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    try plugs and wires, but im willing to bet the cat is bad
  5. #5 Re: Check engine code: P0300?
    Somerdale, NJ
    Could be Upper maniflod leaking coolant. That happen to me and hydrolocked my engine.
  6. #6 Re: Check engine code: P0300?
    Apr 2009
    stockton ca
    could be a fould plug a loose plug wire faulty coil fualty coil conection
    basically start with the easiest
    make sure wires are all connected securley, plugs arent damaged
    you can test the ohms on the wires you will need a basic multi metter they sell at sears for around 20 bucks
    Honestly it gets frustrating diagnoising problems like that so good luck
    gpona.com has a gm service manual link on it maybe that might help you out
  1. Reallly weird check engine code
    By GTBabyGirl in forum Off Topic Discussion
    Last Post: 01-06-2010, 07:49 AM
  2. Check Engine Code Help Please!!
    By TGXP05 in forum 5.3L V8 (LS4)
    Last Post: 10-29-2009, 09:23 AM
  3. Check engine light on. Code: P0481
    By glomgold in forum General Tech Discussion
    Last Post: 03-22-2009, 04:10 PM
  4. Check engine code P0440
    By c002529 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-12-2009, 11:19 AM
  5. Engine Check Light Code List
    By 04CompG in forum General Tech Discussion
    Last Post: 09-18-2008, 12:50 PM
