Thread: Say no to surge
Results 1 to 19 of 19
  1. #1 Say no to surge
    SE Level Member Switzersland's Avatar
    Colorado
    I'm replacing my stock dp and cat on our 2000 Grand prix gt and I was hoping I could get a few suggestion from the crowd here on what to look for and where to shop for a dp & cat welded with 2.25 I/O. I'm replacing as was mentioned to me that the surge in power and the accelerator feathering I have to do to get it up to speed is due to a blocked cat.
  2. #2 Re: Say no to surge
    Willoughby, Ohio
    zzp makes a 2.5in catted downpipe that will come in one peice and will bolt right up to the resonator and rear manifold. its a little bigger diameter of pipeing but it gets rid of the nasty u-bend
  3. #3 Re: Say no to surge
    Charles City, IA
    Quote Originally Posted by CTKGP09 View Post
    That or get a 3" bolt in.
    SMGPFC Two Nipple General
  4. #4 Re: Say no to surge
    3"...catted.
  5. #5 Re: Say no to surge
    Colorado
    Thanks, Will the 3" bolt up as easy as the 2.5?
  6. #6 Re: Say no to surge
  7. #7 Re: Say no to surge
    Willoughby, Ohio
    i just suggested the 2.5 because its closet to stock, but i bought the 3'' dp and i am very pleased
  8. #8 Re: Say no to surge
    Colorado
    Hi Gang, I know it's been over a year. i just purchased the 304ss dp w-cat from zzp. Can i get some install tips as this will be a DIY. I've maintained my own vehicle since my 1974 Opel Manta Rally coupe.
    The Gt still has the same problem with sluggish acceleration on cold mornings, the "EGG" odor is noticeable after a 18 mile commute and the service engine light come on seldom and goes off after a week . other than that the GT runs fine.
    TGIF
    L8TR
  9. #9 Re: Say no to surge
    Florida
    Jack the car up as high as you car. You'll need the room...
    There are a total of 4 bolts you need to remove... 2 on each end of the flanges. (where it meets the cat-back, and where it meets the rear manifold)
    Soak all 4 bolts with Rust Penetrant...like PB Blaster, or the like...and do it a few times...it'll make life easier.
    Remove all 4 bolts, and the rear O2 sensor.
    Put the new gaskets on, and slather them with some RTV....Then tighten down the bolts like all hell, put the O2sensor back in, and you're good.
    It's kind of a PITA to get everything to line up well, but you'll get it after some swearing and hitting stuff.
    And the sluggish acceleration/egg smell...that's a bad catalytic...replacing it with the DP you bought should fix that.
  10. #10 Re: Say no to surge
    Colorado
    Sounds like my Kinda install
    Thanks for the info I appreciate it.
  11. #11 Re: Say no to surge
    Colorado
    ok she's in and the only problem is the oem o2 sensor is too long (that's what she said. sorry, it's friday night). I had to cut some (minor) heat shield, however the stem on the o2 sensor is riding tight against the under body. Do I need to get a special zzp o2sensor? or would a new one from say auto zone fit?
    Thanks again, cheers.
    Ps No bogg, no egg , nice acceleration and kinda throaty now.
    Last edited by Switzersland; 06-03-2011 at 09:18 PM. Reason: 47.99 02sensor @ zzp?
  12. #12 Re: Say no to surge
    take a BFH and smack the area and make more room. Thats what I did with my headers.
  13. #13 Re: Say no to surge
    Florida
    For those not knowing.
    BFH is the affectionate name for a Big ****ing Hammer.
  14. #14 Re: Say no to surge
    Colorado
    ok after one day w/ new dp and cat from zzp-the sluggish take off still exists. plugs and fuel filter are not that old, however could need changed. any ideas? at 3000 rpm's at cold take off, only 15 mph and feathering accelerator.
    ? over
  15. #15 Re: Say no to surge
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    Try cleaning the MAF sensor
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  16. #16 Re: Say no to surge
    Colorado
    Quote Originally Posted by Dtrick22 View Post
    ok thanks
  17. #17 Re: Say no to surge
    Colorado
    I cleaned the MAF sensor and the spring loaded (pressure sensor???) to the feft of the MAF, along the intake manifold. This sensor has an orange "o" ring and was filthy full of carbon. I hope this does the trick. anyone know what the actual nomencalture of the spring loaded sensor?
  18. #18 Re: Say no to surge
    Colorado
    what the going rate for a used cat/platinum collector
  19. #19 Re: Say no to surge
    Jul 2010
    Holyoke, MA
    The sensor you are thinking of is your IAC Valve (Idle Air Control)
    And $60 is a safe bet for what you can get for the used cat, sometimes it is more sometimes less.
  1. Rpm surge help??
    By Darkcelle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2009, 04:13 AM
  2. Engine surge
    By whiteknuckle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2008, 03:32 AM
  3. RPM surge at start?
    By Sabrewings in forum PCM Tuning
    Last Post: 06-07-2008, 06:24 PM
  4. AC compressor is causing my RPM to surge?
    By JCGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2008, 01:48 PM
