Thread: Starts then dies warm
Results 1 to 16 of 16
  1. #1 Starts then dies warm
    SE Level Member trailshredder's Avatar
    Feb 2009
    Central Ohio
    Almost every time I start my car and it is already warm, It will start and then instantly die. Starts right back up and stays running the second try. Anyone else ever have this issue?
    02 Grand Prix GT, Silver with all options.
  2. #2 Re: Starts then dies warm
    Apr 2009
    stockton ca
    sounds like a sensor issue does it have a check engine light on
  3. #3 Re: Starts then dies warm
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    i have, no egine light?? fuel pressure regulator, start ur car pull the vacum line on fuel pressure reg and check for fuel leakin ,if it is replace
  4. #4 Re: Starts then dies warm
    GT Level Member sic6's Avatar
    san marcos, tx
    I would get your ignition control module tested. It could be going out and causes the issues that you are describing.
  5. #5 Re: Starts then dies warm
    Charles City, IA
    I would point towards the ICM to.
    SMGPFC Two Nipple General
  6. #6 Re: Starts then dies warm
    Feb 2010
    Ontario
    I had the same issue on my 04 GT. I took it into a shop to get it looked at. They cleaned the throttle body out and that solved the problem. If I would have known that was what it was, I would have just done it myself.
    Apparently its a tech bulletin for the 04+ models. But it may still apply to yours.
  7. #7 Re: Starts then dies warm
    ^^Nope...just the '04+ cars...its the DBW thing.
  8. #8 Re: Starts then dies warm
    Willoughby, Ohio
    maybe a CPS or MAF sensor or some other sensor just starting to go bad? fuel pump or fuel pressure ragulator starting to go?
  9. #9 Re: Starts then dies warm
    Feb 2009
    Central Ohio
    I am doing the LIM, UIM gaskets and found the PCV valve had a bunch of that nasty tan goop caked in it from a failed LIM gasket. Hoping maybe that was the issue. Should have it back together by the end of the week and will give an update if it is fixed.
  10. #10 Re: Starts then dies warm
    Willoughby, Ohio
    good to know make sure u get all the vaccume hoses and clean REALLY well to prevent it from happeneing again
  11. #11 Re: Starts then dies warm
    Troy mi
    Trailshredder, Did you ever get this problem fixed? Mine does the same thing on the warm start, esp after sitting. Starts fine in the morning. But when its warm, it either dies or bumps to 1500rpm, down to 500 and hunts until it gets the idle corrects. Runs perfect after its started. I also cleaned the IAC and the throttle body intake. All this was after replacing the MAF sensor. Im starting to suspect that the cardone MAF I replaced is faulty. When I unplug the new MAF the staling goes away but there is a small hunt in the idle for a few seconds.
    If anyone else is here and can help, please do. This is my first post.
    Thanks in advance
    Originally, it was intermittently jerking while driving and the code reader said low voltage MAF. The idle problem was not there at this time. I replaced the MAF and that problem went away but now Im left with a new problem.
  12. #12 Re: Starts then dies warm
    Jersey
    Quote Originally Posted by jni99gt View Post
    Thanks in advance
    Is your fuel pump priming?
    16' wrx sti- stock
  13. #13 Re: Starts then dies warm
    Feb 2009
    Central Ohio
    Quote Originally Posted by 99prixgt View Post
    You may be on to something. If I turn the key on and wait a few seconds before starting it, it will always start. Maybe the fuel pump is starting to wear?
  14. #14 Re: Starts then dies warm
    Feb 2009
    Central Ohio
    No, I still have the problem. It seems to have gotten better since the LIM job, but does still happen on occasion. I think my next step I will try is to clean the MAF sensor.
  15. #15 Re: Starts then dies warm
    Charles City, IA
    Yup sounds like your pump is getting weak.
  16. #16 Re: Starts then dies warm
    Jul 2010
    crescent city,calif.95531
    you simply need to remove the air intake tube at the throttle body.open the throttle plate as far as possible,and give it a good cleaning all around.The computer hasnt had time to compensate on the first try.it knows a pre set value to set the idle air control motor.just give that a try. i think you,ll be happy. cause waterboy1 said so.yea.
  1. Car starts then dies
    By Rocket468 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2011, 01:08 AM
  2. Car starts then dies
    By silver2000se in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2010, 06:33 PM
  3. Starts then Dies!
    By 1999GTP1999 in forum General Tech Discussion
    Last Post: 01-29-2010, 08:42 AM
  4. 04 starts then dies
    By oldtruckluvr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-06-2009, 08:09 PM
  5. HELP: Starts then dies after LIM
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 06-23-2009, 03:35 PM
