Thread: Tumbling Rocks
Results 1 to 20 of 21
  1. #1 Tumbling Rocks
    Wichita
    There's a noise coming from under my hood that sounds like something between tumbling rocks & fluttering newspaper. I would assume it's bad S/C bearing but idk for sure. Anyone know what it might be?
    Just when you think you've got all your problems fixed new ones arrive to keep you busy.
  2. #2 Re: Tumbling Rocks
    in a house
    coupler is bad, take off the s/c belt and start the car. If the noise is gone, you need a new coupler
    here> http://www.zzperformance.com/grand_p...=155&catid=106
  3. #3 Re: Tumbling Rocks
    Wichita
    Alright I can do than. Lucky I have an extra nose drive I can use. But, if it is the S/C wouldn't I get that noise all the time & not just when the car is moving?
  4. #4 Re: Tumbling Rocks
    Wichita
    I took the belt off & I still get the noise.
  5. #5 Re: Tumbling Rocks
    swift current,sask.
    Can you get a video of it?
  6. #6 Re: Tumbling Rocks
    Wichita
    No, but i'm wondering if i don't have something loose.
  7. #7 Re: Tumbling Rocks
    GTP Level Member
    Nov 2008
    MA
    valvetrain issue possiblly?
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  8. #8 Re: Tumbling Rocks
    Wichita
    Oooh I hope not.
  9. #9 Re: Tumbling Rocks
    Wichita
    I'll try & get a video put up tomorrow.
  10. #10 Re: Tumbling Rocks
    Jul 2008
    sumter,south carolina
    flex plate? and u posted in N/A section BTW
    02 GTP with mods 05 GP for DD
  11. #11 Re: Tumbling Rocks
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    torq convertor bolts came loose??
  12. #12 Re: Tumbling Rocks
    Wichita
    I'm wondering if it's the tranny. It's been shifting funny.
  13. #13 Re: Tumbling Rocks
    Feb 2010
    ohio
    get under there and tighten the torq converter bolts see if that fixes the problem
  14. #14 Re: Tumbling Rocks
    Wichita
    If it were any of those problems I would here the noise @ idle & I don't. It is something loose >_< I just don't know what. Unless. . . a bad strut can cause weird noises like that.
  15. #15 Re: Tumbling Rocks
    swift current,sask.
    Can you find out the general area the sound is coming from?
  16. #16 Re: Tumbling Rocks
    Wichita
    Sounds like its coming from right under the hood close to the firewall.
  17. #17 Re: Tumbling Rocks
    swift current,sask.
    trans, downpipe???
  18. #18 Re: Tumbling Rocks
    Wichita
    Im wondering about the transmission =/
  19. #19 Re: Tumbling Rocks
    Feb 2010
    ohio
    i had a caddy come into my shop and only under a load would it make this weird a$$ sound i guess like tumbleing rocks coudnt tell were it was coming from i put it on the rack and stuck my ear up to it after i had it under a load (sum1 power braking it) was comeing from bottom of the trans pulled starter and plastic cover torq convertor bolts were loose as hell took um out lock tighted umm havent seen car since that was over 2 yrs ago,, mite not be your problem just a thought dont hurt to check.
  20. #20 Re: Tumbling Rocks
    Jul 2008
    im puttin my money on broken flex plate.
  1. This Site Rocks!!!!
    By HVanzzini in forum Introductions/Noob Questions
    Last Post: 01-09-2010, 07:12 PM
  2. Grand prix rocks!
    By 02 grand pirx in forum Introductions/Noob Questions
    Last Post: 12-31-2009, 04:15 PM
