Thread: Engine mounts?
Results 1 to 15 of 15
  1. #1 Engine mounts?
    Kansas
    Best place to get stock upper engine mounts?
    SOLD 1999 GT Silvermist TS
  2. #2 Re: Engine mounts?
    why would you want stock uppers? the poly ones are a thousand times better.
  3. #3 Re: Engine mounts?
    GT Level Member gtryda's Avatar
    Feb 2009
    Ohio
    What exactly do poly mounts do?? This guy is trying to sell me some for 100 bucks
    A Beast In the Making
  4. #4 Re: Engine mounts?
    GTP Level Member
    Nov 2008
    MA
    Quote Originally Posted by gtryda View Post
    well then that guy is high..you can get some on w body store.com for 30+ shipping or zzp 60 + shipping
    the stock rubber motor mounts compress when the engine rocks..stock ones esp with high milage are very squishy and have too much play so poylurathane ones are more solid and help when launching your vehicle..helps esp at the track. wbodystore.coms are a not as hard as zzps FYI. people have had problems with vibration with more solid mounts, so i went with wbodystores. poly mounts= better launch, more power to the wheels pretty much,,hope this helps bud
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  5. #5 Re: Engine mounts?
  6. #6 Re: Engine mounts?
    Kansas
    I dont like the vibrations. for some reason they are outrageous on my car
  7. #7 Re: Engine mounts?
    i had little to no vibration from the poly mounts. my vibrations were from having no balance shaft.
  8. #8 Re: Engine mounts?
    Kansas
    Well all i have is the poly mounts.. It vibrates alot and when i turn the wheel a little when at a light it vibrates a lot.
  9. #9 Re: Engine mounts?
    Feb 2009
    Ohio
    Thanks man that did help alot. Had the feeling they were a little to overpriced for what they looked like an the price he was askin so i didnt buy em. Ima jus order them from intense website or go pick em up from there. What exactly do u mean by vibrations, Does thr car shake more or somethi when theyre on.
  10. #10 Re: Engine mounts?
    Kansas
    Still wondering where to get stocks?
  11. #11 Re: Engine mounts?
    Donating Users kfish's Avatar
    Ohio
    go to the parts store.
  12. #12 Re: Engine mounts?
    GTP Level Member
    Nov 2008
    MA
    im thinking they vibrate more or less because now the motor doesnt have any play from the poly motor mounts like they did with the stock rubber ones..idk i could be wrong though. some ppl have the issue where others do not. launch your car before and after the poly mounts are on and you wont put the stockers back on ever
    99 GTP - DD
  13. #13 Re: Engine mounts?
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    Quote Originally Posted by kfish View Post
    this. haha
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  14. #14 Re: Engine mounts?
    Feb 2009
    Ohio
    Yea i just put on a pair on my car last weekend. I did notice a difference. Seems like when u step on the gas u get a quicker response than before but i do notice that my steering wheel vibrates more. Nothin major but still noticable. Ill still keep them on tho well worth it.
  15. #15 Re: Engine mounts?
    Get some from Morad most likely.
    And...if you think your engine vibrates too much and your modding it...then don't mod it.
  1. Autozone SOLID engine and trans mounts
    By Abrasive in forum Shops and Community Heroes
    Last Post: 08-17-2009, 08:19 PM
  2. Painting my engine mounts today!!
    By kjclawson in forum Visual/Body Modifications
    Last Post: 08-16-2009, 10:53 PM
  3. Strengthen Front Engine Mounts (Torq Bars)
    By Joe8389 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-17-2009, 02:03 PM
  4. engine mounts?
    By elusive racing in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2009, 10:44 PM
  5. motor mounts
    By dmoney01 in forum General Tech Discussion
    Last Post: 03-01-2009, 01:35 PM
