will l67 injectors be a direct swap in or do i need use the l67 plug
l67 injectors will be a straight swap with a tune. they bolt in and work, but wont work without you making sure your fueling is correct, but why do you want them? you have no need for more fuel.
You will need to swap the plugs as well. I think it was in 2000 that the L36 switched to Multec II connectors where the L67 stayed with the EV1 connectors.
ya my car is a 01 i got the wires with them they were free so what the heck im adding a l67 tb and a cutom tune in march from overkill got my jeep going whil the gp is down is the l67 maf sensor the same or do i need to use my l36 sensor thanks for all the help guys saves me the headach
