yeah im wondering what is the problem wit the Tog. i just wanted to get Power Log & Ported Manifold just because they are somewhat cheap but good for n/a.
If I were you, I'd just do the Powerlog and maybe ceramic crossover. The rear manifold is pretty good on its own so you probably wouldn't see any significant gains to be worth it. Kinda a ***** to do.
Later on if you feel its holding you back, do it then.
i dont know i might just buy the whole set up. yeah the Ceramic coated crossover pipe might be something else to look at. so far i have these im strongly going to buy.
1.Ceramic coated crossover pipe
2.Downpipe
3.Power Log & Ported Manifold
4.U Bend Delete
Not necessary. You can save some money by buying a 2" wide, 15' roll of header wrap. Did mine that way and it was pretty easy and effective.
No need for a u-bend delete as a bolt-in downpipe will have that already deleted. I agree with the suggestion to skip the rear ported manifold. Save your money on that and put it into the rocker fund. The rear PEM will give you like 3 hp at best probably. If you take apart your exhaust in one sitting, you could just use a dremel to touch up your stock rear manifold if it even needs it.2.Downpipe
4.U Bend Delete
