Thread: whats the most you can make n/a?
Page 7 of 7 FirstFirst ... 567
Results 121 to 139 of 139
  1. #121 Re: whats the most you can make n/a?
    Quote Originally Posted by cellurbb View Post
    Ok and?
    Thanks, since the last post was:
    05-04-2010, 04:11 PM
  2. #122 Re: whats the most you can make n/a?
    Banned
    Milwaukee
    O i know lol! I was just wondering what were you getting at that's all.
  3. #123 Re: whats the most you can make n/a?
    Troy OH
    he probably doesn't remember...
  4. #124 Re: whats the most you can make n/a?
    That your grammar, sucked.
    Use F7.
    That's wutiwazgettinatbruh.
  5. #125 Re: whats the most you can make n/a?
    Topeka, KS
    F7 only works in MS word.
  6. #126 Re: whats the most you can make n/a?
    Troy OH
    your mother only works in microsoft word
  7. #127 Re: whats the most you can make n/a?
    Topeka, KS
    Nah she works in DOS too.
  8. #128 Re: whats the most you can make n/a?
    Banned
    Milwaukee
    Use F7.
    Yea ok old man its not like im in a class room doing a essay
  9. #129 Re: whats the most you can make n/a?
    Chicago, IL, USA
    I know this is an old thread, however the question was asked: 193whp & 262wtq on ZZP's dyno, on stock GM cam(current record holder). No, I did not spend thousands. A stock GTP will only start to pass me at 37mph. The HV3 has been improved in the last 1.5 years as a molded 1-piece unit, ZZP's Stage1 TB is a good unit. The PLOG will gain a little TQ, not loose it, PEMS are a waste. A CAT-BACK will loose TQ, while a down-pipe will gain. Head mods to run low 14's: .035 milling(true 10:1), extensive porting, REV valves with under-cut valve stems, sizes 1.84-1.9 intake & 1.6 exhaust, Yellow LS6 90 lb. springs with 1.95 YellaTerra aluminum rockers. Fully ported LIM(Milzy). Under-drive water pump pulley & 180. The only trans mod needed is a shift kit. An external cooler adds weight and adds to the probability of leaks. If you are really worried about trans cooling, swap your steel trans pan for a finned aluminum pan.
  10. #130 Re: whats the most you can make n/a?
    Troy OH
    good post sir. sidebar, how was dealing with milzy? they're really close to me and i was hoping they could do my tuning
  11. #131 Re: whats the most you can make n/a?
    Kansas
    The end of page 6 is full of weaksauce. That is all.
  12. #132 Re: whats the most you can make n/a?
    Great White North
    with the top end, 325-355 hp is achievable for a street engine (not cheap), and 450-500 hp on a race engine. 3.8L
  13. #133 Re: whats the most you can make n/a?
    Quote Originally Posted by cstavro View Post
    LOL...wut.
  14. #134 Re: whats the most you can make n/a?
    utah
    Ha! I want my 3.8 to be RACE
  15. #135 Re: whats the most you can make n/a?
    Great White North
    i developed a CNC porting program for the L32/L67 two years ago. its absolute performance was disappointing to me, and the cost was too high for what it was. I've been designing aluminum heads which use state of the art ports. they will flow well over 300 cfm - they're not bolt on. The relocated valves and port locations require a new intake manifold, and new headers - and may not fit in a w body. 500 hp comes at 8000+ rpm...big cam, titanium valves, rocker arms, forged internals, etc. the 3800 was designed as a low speed engine (with ****ty ports), so you can imagine that it takes a lot to get it to spin fast - a lot of money!
  16. #136 Re: whats the most you can make n/a?
    utah
  17. #137 Re: whats the most you can make n/a?
    I'd bet mine spins just as fast...and I didn't spend your average adoption costs to get there. It's called balanced and lightened rotating assembly, guy.
  18. #138 Re: whats the most you can make n/a?
    Great White North
    I wasn't bull$hittin. This was a relatively quick model of a tall port race-ready head for the 3800. This has been on my mind for years. I like the look of the SB2 and Mopar W9 heads. My enthusiasm for this project was dampened with the rumour of the LV3 gen v ls based V6 allegedly due next year.
    Tickling 300 cfm with a 1.89" intake valve, and the minimum port area is no bigger than the stock gasket! Right about 400 bhp on a streetable engine - big lope and pump gas. Relocated exhaust port flange. Requires custom intake, coolant cross over/valley tray, valve covers, shaft mounted rockers, valves and header flanges. As it stands, I could have this machined, bolt them up and make power...ethanol only - the accessory bosses are not shown.
    In reality, I need to start with peanut ports and develop the ports. Someone has already approached me to make this...I'm still open to this project
    I may have connections to have this cast with coolant jackets. Realistic price would be below ZZP's, even with the required hardware, and they've ended production. Even as cast they'd bury the ZZP head.
    whats the most you can make n/a? Attached Images
  19. #139 Re: whats the most you can make n/a?
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Some of you might remember this car from back in 2004/05. I had the highest dyno for an NA car (for a week) at 233 hp. The mods are in the video.. but a quick breakdown.
    GT1 cam
    Milzy stage 2 heads 90 lb LS1 valve springs
    shifted at 6800 rpm (lolcopter)
    3800 stall
    S&S headers
    other minor stuff ( can't remember it all), but that was the major parts.
    Video of my LTZ - Car Videos on StreetFire
    and yeah.. that's my Lumina on Milzy's website.
    No offense to the NA peeps here. It was fun while it lasted when I was NA. Just dumping that much money into an NA FWD car was pointless.
    I sold the heads, cam package for about $1300. Got the GTP motor for $800 and went 13.9 with a bad fuel pump a few weeks later.
  1. anyone want to make me a sig?
    By shawn3091 in forum Off Topic Discussion
    Last Post: 01-05-2010, 05:48 PM
  2. Make a GT into a GTP, p.i.t.a. ? Anyone do it?
    By Purple Plazma in forum General Tech Discussion
    Last Post: 11-20-2009, 09:00 PM
  3. If if dont make money it dont make cents
    By CrAnK_DaT_SoUjA_BoI in forum Introductions/Noob Questions
    Last Post: 08-18-2009, 01:00 AM
  4. do they make these?
    By riceburner in forum Visual/Body Modifications
    Last Post: 12-01-2008, 10:13 AM
  5. This Will Make Your Day
    Last Post: 07-28-2008, 04:29 PM
