Thread: coolant leak on a 3.8
Results 1 to 4 of 4
  1. #1 coolant leak on a 3.8
    Aug 2014
    Wyoming
    Hey guys I've got a 2008 grand prix with the 3.8 v6. It has 130xxx miles on it. It has a coolant leak and im not for sure where. I replaced the two plastic elbows on the tensioner, I put a new water pump and a new t-stat. When I had it all apart I was looking around the manifold and it wasn't wet the oil isnt milky either. The spot that I have noticed is wet is behind the the motor, the side where the exhaust manifold goes to the exhaust pipe. Im stumped because from what I can see and feel on the motor I cant find a spot. Any help would be appreciated, thanks.
  2. #2 Re: coolant leak on a 3.8
    Aug 2013
    arlington, tx
    Sounds like it's time to do a LIM job
  3. #3 Re: coolant leak on a 3.8
    Check the ends of your heater hoses. Just feel them. You will likely find the end at the tensioner is leaking. Likely it's an o-ring where the fitting goes into the tensioner.
  4. #4 Re: coolant leak on a 3.8
    go buy a coolant pressure tester, or rent one. pump up the rad with it, look for a leak to appear.
    lims dont really piss coolant. the bolts can seep coolant,
    get under the car look up to the freeze out plugs in the block, one of them may have rotted out on you.
  1. Coolant Leak
    By blackthunder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-31-2013, 09:56 PM
  2. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  3. Coolant Leak
    By 99grandprixman in forum General Grand Prix Discussion
    Last Post: 01-06-2013, 06:43 PM
  4. Coolant leak NEED HELP!
    By nickskip08 in forum Introductions/Noob Questions
    Last Post: 01-03-2013, 10:05 AM
  5. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
