Thread: L67 swap into a 99gt
Results 1 to 20 of 20
  1. #1 L67 swap into a 99gt
    SE Level Member NineD9GT's Avatar
    Dec 2008
    PA
    I hope you guys don't get pissed for me asking this, but I'm having no luck searching for info on this. I'm buying a wrecked 97 GTP to use as a donor car for my 99GT. What all will I need to use off of this car? I was thinking about dropping complete cradles, and swapping. Aswell as wiring in engine comp and computer. What about fuel pump? Do I need any other wiring for this? Thanks
    Dan
  2. #2 Re: L67 swap into a 99gt
    Jul 2008
    sumter,south carolina
    02 GTP with mods 05 GP for DD
  3. #3 Re: L67 swap into a 99gt
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    Top swaps are ghey! Motor swap FTW haha.
    Here's a writeup a friend Marc and I made on swapping the entire L67 motor into a L36 powered car. Dropping the cradle in my mind would make your job harder. Just pick up a hoist.. That being said, computer will require tuning, stock L36 fuel pump will be fine, and stock wiring is fine. Don't let anyone tell you otherwise. Anyhow, here's the link to the writeup
    L67/L32 Motor Swap (W-body) - Complete Guide
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  4. #4 Re: L67 swap into a 99gt
    Nov 2008
    Also, I should note that there will be an additional tree on a 97 M90 case that will need to be plugged using on a 98+
  5. #5 Re: L67 swap into a 99gt
    Why no top swap love?
  6. #6 Re: L67 swap into a 99gt
    Top swaps FTW...I'd keep the stock bottom end and get a PCM that is already tuned. Again...like said there are some differences with the '97 vs. a '99...PM a little Nancy on here named 99prixgt...he top swapped his '99 and can point you in the right direction with stuff
  7. #7 Re: L67 swap into a 99gt
    Nov 2008
    I like reliability and most top swaps have a life expectancy of what, a year tops?
  8. #8 Re: L67 swap into a 99gt
    Jersey
    top swap FTW. Its reliable, no matter what anyone says. I constantly beat on my car. Im still on a stock pulley, and beat up 3.4 L67 setups
    16' wrx sti- stock
  9. #9 Re: L67 swap into a 99gt
    Quote Originally Posted by 99prixgt View Post
    How much timing are you running?
  10. #10 Re: L67 swap into a 99gt
    Jersey
    yeah, im kind of a big deal
    16' wrx sti- stock
  11. #11 Re: L67 swap into a 99gt
    Quote Originally Posted by ninnyGTP View Post
    prove it.
  12. #12 Re: L67 swap into a 99gt
    Jersey
    not sure, im using an intense pcm, when dave @ 3ep looked at it, he said the timing is really conservative. The car really needs a dyno tune. If you know what your doing and have all the supporting mods a m90'd L36/26 is just as reliable. To pop a piston or spin a bearing is from someone doing something wrong.
    Im only on 5psi, 8 if its below 26*, i get very little knock even in 18* weather. Most i had so far was 1.6* of knock in the top of 2nd gear
    16' wrx sti- stock
  13. #13 Re: L67 swap into a 99gt
    Nov 2008
    Keyword being stock pulley
    3.4 L67's are ghey.. Especially since 90% of them asre on a stock motor
    prove it.
    How would you like me to do that haha. I'm not knocking them, i'm just saying to me the better route is a full swap. If you want that extra power, buy a GenV
  14. #14 Re: L67 swap into a 99gt
    Donating Users kfish's Avatar
    Ohio
    my tops swaps reliabale , it gives you a chance to go through the top of the motor while you do it. or in my case...the whole motor
  15. #15 Re: L67 swap into a 99gt
    Topeka, KS
    You'll make more power out a top swap too. High Compression Motor FTW!
  16. #16 Re: L67 swap into a 99gt
    Nov 2008
    Really just comes down to preference I suppose.
  17. #17 Re: L67 swap into a 99gt
    Jersey
    g8 gt? from a stop i put a car on him till 75. From a 60-100 roll i had a half a car on him, all on stock pulley.
    Or buy a genV and throw it on a L36
    16' wrx sti- stock
  18. #18 Re: L67 swap into a 99gt
    Nov 2008
    I'm not bashing your car or questioning what it's capable of. Just stating the obvious about 3.4 L67's haha
    OOOOR, you can just buy the whole L32 more (check signature)
  19. #19 Re: L67 swap into a 99gt
    Aug 2014
    veedersburg, in
    can you post a good link? that one is an ad
  20. #20 Re: L67 swap into a 99gt
    Aug 2011
    'Merica
    Bravo.........posting in a 4 year old thread.
  1. Top Swap Help
    By kfish in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-11-2009, 04:53 PM
  2. LS 4 conversion 99gt??
    By gtryda in forum 5.3L V8 (LS4)
    Last Post: 11-10-2009, 12:10 AM
  3. my 99gt vs 01gtx accident
    By gtryda in forum Track Sessions and Kills
    Last Post: 10-30-2009, 01:42 AM
  4. GT Top Swap
    By cboth686 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2009, 11:45 AM
  5. Top swap pcm
    By skidoojames151 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-23-2009, 03:47 AM
