Thread: how reliable are our fuel pumps?
Results 1 to 12 of 12
  1. #1 how reliable are our fuel pumps?
    New Jersey
    Hey, I remember back in the late 80s early 90s electric fuel pumps failing pretty easy and things like running your tank below 1/4 simply speeding the process up.
    are the electric fuel pumps in newer cars this fragile?
    How have the returnless pumps been as far as reliability?
  2. #2 Re: how reliable are our fuel pumps?
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    My fuel pump has 165k miles on it. Answer your question?
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  3. #3 Re: how reliable are our fuel pumps?
    New Jersey
    Quote Originally Posted by a98gtp4u View Post
    No it does not. I had 168K on a 1992 one due to being very careful to keep a lot of fuel in the tank. ran it low ONCE, it was dead.
    How do they handle being operated low on fuel? Does running the tank down until the low fuel light comes on cause failures etc,
  4. #4 Re: how reliable are our fuel pumps?
    GEORGIA
    It hasnt on mine yet, ive ran it real low a few times. I try not 2 tho, but its happened.
  5. #5 Re: how reliable are our fuel pumps?
    New Jersey
    thats good to hear . Maybe i've been scared of something for awhile that doesn't even exist anymore.
  6. #6 Re: how reliable are our fuel pumps?
    the fuel pumps are pretty well off on these cars, you can usually run them for a very long time. when you start to see fatigue is when you start pushing a lot of power and the pump can no longer keep up with the injectors.
  7. #7 Re: how reliable are our fuel pumps?
    PA
    Mine lasted until 229k miles. I always run it down till I am almost out of fuel. Even ran out a few times. No issues.
    2001 GSE
  8. #8 Re: how reliable are our fuel pumps?
    Jul 2008
    sumter,south carolina
    mine pops fuses if i get wayyyyyyyyy low on gas.
    02 GTP with mods 05 GP for DD
  9. #9 Re: how reliable are our fuel pumps?
    GT Level Member hourang's Avatar
    commerce, mi
    older tanks didnt have the baffles in them that newer tanks do. in the older cars, if your low on gas and hit a hard enough turn it will run the pump dry and hurt it. on newer cars theres a baffle that always has fuel in it until you are completely empty.
    -Jeff
    98 GTP Black 4dr - fully loaded - short ram intake, tinted tails, hole in resonator.
    sold 98 camaro ss - 6spd fully loaded - cam, intake, exhaust, ford 9in rear 4.11s, 6point chromoly cage, tnt 150shot nitrous, nittos, etc.
  10. #10 Re: how reliable are our fuel pumps?
    Charles City, IA
    Running the car low on fuel is not good at all for the fuel pump. Keep it above 1/4 tank, when it is low on fuel the pump is not completely submerged and gets hot. The heat is what kills it.
    SMGPFC Two Nipple General
  11. #11 Re: how reliable are our fuel pumps?
    SE Level Member nault31's Avatar
    Southside Chicago Suburbs
    ^^ I think the same is true for most any car.
    I know somebody who bought a POS 98 GTP and we had to change the fuel pump, even if they go bad we're lucky to be able to change them from the trunk without dropping the fuel tank.
    ^^I realize a stock L36 is not as fast as the sticker implies, but this sticker has worked and it is still a hell of a lot of fun to drive considering it's a grocery sedan.
  12. #12 Re: how reliable are our fuel pumps?
    Charles City, IA
    Yeah I was talking in general. Unless you have a mechanical pump.
  1. Fuel Pumps
    By JayAz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2010, 03:25 AM
  2. just when i think I have a nice reliable car...
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-25-2009, 04:30 PM
  3. Diff. in SE, GT, and GTP fuel pumps?
    By PCweber in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-09-2009, 10:56 AM
  4. 3.4 reliable setups ideas what shud i do
    By Soloaded in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2009, 08:55 PM
  5. Gas Pumps
    By Abrasive in forum The Rant Forum
    Last Post: 02-03-2008, 10:25 AM
