Thread: Ported LIM for N/A Guys...PICS!
Results 1 to 20 of 24
Threaded View
  1. #1 Ported LIM for N/A Guys...PICS!
    So...for all you guys not wanting to top swap or can't afford it...I got bored today and hogged the crap out of a L36 LIM. Looks pretty sweet too. I guess I can start selling these if I get enough people interested. IMO, it would be a more beneficial gain if you have a HV3 installed...but it sure wouldn't hurt a car without one. Pics will be up soon. Won't be too expensive either. Figuring around $100 shipped plus your stocker. I'd love to get this thing on a dyno for some before and after gains but I don't have that kind of access.
    Specs on this puppy are...
    Stripped, Cleaned, Painted a color of your choice (within reason...I won't do House of Color Tangerine or something ). Intake is opened up appox. 5mm all around the upper portion and the runners are enlarged a few mm also. Runners have nipples/bumps removed for better flow/less restriction. Runners are also finished comparable to that of 200-ish grit sandpaper, since you want the intake side to be a bit rough...compared to the exhaust side which you want smooth. I will be starting on heads soon...not the bowls, just the intake/exhaust ports. I don't want to mess with the bowls...I've tried...just not good enough for that yet...as I'm a perfectionist and it didn't turn out quite the way I had hoped it would.
    But back to the Ported LIM. Figuring this is a little comparable too...
    Stock L36 to a Custom Ported LIM
    Stock LS1 IM to a FAST Setup
    I'm not sure on flow specs of the LS1/2/6 vs. the FAST setup as I know they see pretty good gains from it...so not THAT good. But, for sure better than stock. Let me know what you guys think.
    Nick
    Last edited by blueguy; 12-06-2009 at 07:47 PM. Reason: Because people are symbol challenged.
  1. Lower Intake Manifold
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 10:44 PM
  2. Lower intake manifold
    By FuglyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2009, 10:40 AM
