Thread: New air fliter setup
Results 1 to 14 of 14
  1. #1 New air fliter setup
    SE Level Member Pontiac Warrior's Avatar
    Hudsonville
    I am looking at putting a spectra cone filter in my car with a chrome elbow what size am i going to need and are there any mods other than slapping it in i am going to need to make? Any help would be appreciated!!
    Pontiac Warrior
  2. #2 Re: New air fliter setup
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    what year car u got? make a 4" out of pvc pipe with the real big spectre filter.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  3. #3 Re: New air fliter setup
    Hudsonville
    2001 gp gt
    Pontiac Warrior
  4. #4 Re: New air fliter setup
    Safely Modding Your 3800 READ IT. There is a link on a DIY Fenderwell setup.
  5. #5 Re: New air fliter setup
    GXP Level Member
    Theworld
    Elbow + 7" Specture filter... and you're good.
    Make sure you have a fitting for the sensor in the elbow, and as far as the PCM goes, I just let mine sit there.
  6. #6 Re: New air fliter setup
    Hudsonville
    What diameter cone?
    Pontiac Warrior
  7. #7 Re: New air fliter setup
    4" inlet...as big of a filter as you can get.
  8. #8 Re: New air fliter setup
    Hudsonville
    What do you do about the air sensor?
    Pontiac Warrior
  9. #9 Re: New air fliter setup
    drill hole, install rubber gromet, stick sensor in
  10. #10 Re: New air fliter setup
    Hudsonville
    awsome thank you so much!
    Pontiac Warrior
  11. #11 Re: New air fliter setup
    Hudsonville
    Filter is on and what a difference it makes! Thanks Guys
    Pontiac Warrior
  12. #12 Re: New air fliter setup
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    ive got the bigg spectre filter in my fenderwell, it was really really had to fit....i used the 4" bendy air intake hose from pep boys that people on here advise against. but it works great, and i've yet to see bench flow numbers proving it wrong.
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  13. #13 Re: New air fliter setup
    Put a piece of pipe in there that DOESN'T bend...example...a 4" piece of PVC...and you'll see.
  14. #14 Re: New air fliter setup
    no bends or SMOOTH bends. a 90* into the fender is ****ing you over.
  1. my old setup
    By whitcomb in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2009, 06:49 PM
  2. Issues with the stock air fliter box
    By Dagujugrandprix08 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2009, 11:53 PM
  3. New setup
    By b00stinGTX in forum Brakes/Suspension/Chassis
    Last Post: 02-25-2009, 11:00 PM
  4. 3.29 Gear Setup
    By 98GTPON22s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-03-2009, 08:23 PM
  5. this setup
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2008, 08:47 PM
