Thread: Tired of this problem
Results 1 to 20 of 21
  1. #1 Tired of this problem
    SE Level Member Skeeve's Avatar
    carneyville FL
    Ok guys, and gals... my 99gt is tickin me off, it usually dies on me about 3 or so miles down the road after i first start the car, what ive noticed, if i take the oil fill cap off and wait 5 or so min, it will start right up, further into that, i get a white vapor that comes out of the oil fill, i had one guy (in a gp gt) whip it around today and stop to offer help (cause GP'ers gotta stick together right) he said odds are its the plenum or the gasket. im losing coolant constantly as well, its gotten to the point where i dont even put coolant in anymore i can drop easily a 1/2 gallon in a day or 2 no unusual overheating though.... any ideas? (i only have around 300 to spend) I need to get this fixed, my job requires that i drive all over all day long.
    99 Grand Prix GT
  2. #2 Re: Tired of this problem
    Kansas
    do you have water in the oil???? or oil in the water????? do you see the coolant leaking???? and have you changed your PCV valve??
  3. #3 Re: Tired of this problem
    carneyville FL
    no water or oil mixing
    cant see it leaking
    and no i havent replaced it
    99 Grand Prix GT
  4. #4 Re: Tired of this problem
    Wichita
    Is your fuel pump working properly? Or your leaking coolant in through the LIM.
  5. #5 Re: Tired of this problem
    carneyville FL
    fuel pump is working fine, and i dont know where im leaking from
    99 Grand Prix GT
  6. #6 Re: Tired of this problem
    Wichita
    LIM gaskets go bad in these cars. Get the Metal LIM gasket from Pontiac or wbodystore.com or wherever & replace that plastic leaky thing.
  7. #7 Re: Tired of this problem
    carneyville FL
    so youre saying its the lim and not the plenum gasket?
    99 Grand Prix GT
  8. #8 Re: Tired of this problem
    SE Level Member 1bad3800's Avatar
    Jan 2009
    bensalem pa
    i have a l.i.m if you need that i can let go pritty cheep if you are intrested..... if you need that
  9. #9 Re: Tired of this problem
    carneyville FL
    how much to with shipping to 33534
    got pics?
    99 Grand Prix GT
  10. #10 Re: Tired of this problem
    does it make a loud hissing noise when youre driving it? like its building up a lot of pressure? could be a junk PCV.
  11. #11 Re: Tired of this problem
    carneyville FL
    i do get a hissing sound sometimes, it sounds like its coming from underneath on the driver side
    99 Grand Prix GT
  12. #12 Re: Tired of this problem
    Kansas
    the first thing I would look into is the coolant leak. find out where it is leaking for sure and take it from there.
  13. #13 Re: Tired of this problem
    Guam
    Quote Originally Posted by Hoganperformance View Post
    Right on!
    You have to addresst this first and should not ignore and keep driving it.
    I mean really, how can you expect the engine to run properly if it keeps ingesting, or burning up coolant?
  14. #14 Re: Tired of this problem
    carneyville FL
    Quote Originally Posted by toolguy View Post
    Right on!
    which is the reason why i was asking about the plenum, i cant afford to just tear the engine down to find the problem, im looking for odds like "odds are its probably the plenum gasket"
    99 Grand Prix GT
  15. #15 Re: Tired of this problem
    Odds that it might need all new gaskets top end wise.
    LIM, UIM, TB, new vacuum lines since dry rot is a big issue. New T-Stat and coolant flush to get rid of the crapxcool...and replace with the green stuff.
  16. #16 Re: Tired of this problem
    carneyville FL
    vacuum lines seem to be in good shape, dont look dry rotted, just dropped tstat in not too long ago already got rid of crapxcool
    but as for the rest, thats probably what i'll do
    thank you
    99 Grand Prix GT
  17. #17 Re: Tired of this problem
    Kansas
    any shop should be able to tell you where your leak is coming from. They can pressurize your cooling system and pin point it.
  18. #18 Re: Tired of this problem
    carneyville FL
    and ill start by doing this, just to make sure i need all the gasket changing
    99 Grand Prix GT
  19. #19 Re: Tired of this problem
    carneyville FL
    well, there is a pinhole leak in the radiator, could that cause me to lose a gallon every few days?
    99 Grand Prix GT
  20. #20 Re: Tired of this problem
    Donating Users kfish's Avatar
    Ohio
    it could, are you leaving puddles where you park? and smell your exhaust. if it smells sweet your burning coolant. you could have both things wrong lol
  1. Problem!
    By pure in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-13-2009, 11:07 PM
  2. Gas Problem
    By flynn in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-07-2009, 10:27 PM
  3. YO...tired of the drama on CGP so thought I would join here!
    By JEFFSGTP in forum Introductions/Noob Questions
    Last Post: 11-22-2008, 01:08 PM
  4. AC problem
    By evilpacker in forum General Tech Discussion
    Last Post: 07-22-2008, 04:34 PM
  5. Tired of IT - CV Boots/Axels
    By japslpr in forum Brakes/Suspension/Chassis
    Last Post: 02-10-2008, 12:20 PM
