Thread: Car is running like ass with muddy coolant
Results 1 to 5 of 5
  1. #1 Car is running like ass with muddy coolant
    SE Level Member intervention's Avatar
    Nov 2009
    Rochester Minnesota
    So I was driving my 98 GT today.. Everything was great, til it just started misfiring. It was bearable until I could take a look at it, then the SES light came on. Figured it was nothing. Then it started flashing. I looked at my temp gauge and it was at 230, usually it's at like 170 or something. Then it smelled like crap coming from the tailpipe, so I assumed it was a plugged cat. Then I popped the cap on my radiator and the coolant looked sludgy as hell. now it will not start, it just cranks over.
    1999 Pontiac Grand Prix GT - Daily Driver
    1999 Dodge Durango 5.2l - Bad Biatch
    2000 Honda Accord EXL-V6 Coupe - Secondary Driver
  2. #2 Re: Car is running like ass with muddy coolant
    PA
    Okay, couple things here. The blinking SES light means that you are having tons of misfires. So there is something keeping the spark plugs from firing. And the high temps are probably because you were running the car hard. Or...it was low on coolant. But the crappy coolant doesn't help.
    I am going to guess that your LIM gaskets are bad. This would feed coolant into the combustion chamber, causing it to run bad, cause misfires, SES light, etc. In turn, if the LIM gaskets have not been changed, the coolant probably hasn't either. So it either has oil in it, or just gunked up from being old.
    My suggestion is take a look at your oil. If they gaskets are leaking that bad, you probably have coolant in your oil and the oil will look milky. Regardless, pull your spark plugs and see if you have coolant in the cylinders. That would point to a lim gasket failure to me.
    2001 GSE
  3. #3 Re: Car is running like ass with muddy coolant
    Nov 2009
    Rochester Minnesota
    okay.. i scanned it with my tool and 2 cylinder 6 misfires came up but that's it.
  4. #4 Re: Car is running like ass with muddy coolant
    Nov 2009
    Rochester Minnesota
    oil is not milky either.
  5. #5 Re: Car is running like ass with muddy coolant
    Nov 2009
    Rochester Minnesota
    never mind, my head gaskets blew.
  1. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  2. Trying to get 2.8 running again!
    By 1988 Grand Prix in forum General Tech Discussion
    Last Post: 10-03-2009, 12:35 AM
  3. Got my car running!!!
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 08-02-2009, 01:58 PM
  4. Why am I running so hot?
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2009, 05:22 PM
  5. who is running E85?
    By Bio248 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2009, 06:25 PM
