Thread: having troubles with load on engine
Results 1 to 14 of 14
  1. #1 Re: having troubles with load on engine
    Cushing, Oklahoma
    actually only replaced the spark plugs on the front (the easy to get to) none of the plugs showed any wear nor did the wires appear to have mis-firings.
    cut one of the wires while trying to get it off the plug hence the problem with the first cyl. firing, so I bought wires but just replaced that one... The flashing SES light only appears when climbing a steep hill with the pedal floored and clears shortly after. Can it still be in the firing?
  2. #2 Re: having troubles with load on engine
    PA
    Quote Originally Posted by tonydtech View Post
    Yup, I would recommend to replace all the plugs and wires.
    2001 GSE
  1. Electrical Troubles
    By Orozco in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 12:00 AM
  2. Need some help with amp and sub troubles
    By Thunderturd in forum Audio, Security & Visual Electronics
    Last Post: 08-20-2009, 02:51 AM
  3. engine can't handle load...
    Last Post: 05-02-2009, 02:51 PM
  4. downpipe troubles, advice?
    By Jakegday in forum General Tech Discussion
    Last Post: 04-29-2009, 06:26 PM
  5. Mass airflow sensor troubles!
    By Bruty74 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2009, 03:33 PM
