Thread: ROUGH IDLE when Warm STILL :(
Results 1 to 12 of 12
  1. #1 ROUGH IDLE when Warm STILL :(
    Dec 2011
    IL
    Alright, so i posted about a rough idle awhile back and took a few suggestions but the issue is still there. Update: 1999 GT 3.8. Once driven to operating temps, once turned off and restarted shortly there after, it has a very rough idle. It didn't throw an engine light codes until about a week ago. Once I arrived at autozone to get the codes checked out, it went off. They went ahead and plugged it in, it was showing cylinder 2 misfire. In the last month I have replaced the plugs, wires, IAT sensor, cylinder 2 coil, fuel filter. Do you guys have any suggestions before I put a bullet through the gas tank? Thanks guys!
  2. #2 Re: ROUGH IDLE when Warm STILL :(
    Did you put ac delco plugs back in?
    Also is there misfire still on a cylinder(s)?
  3. #3 Re: ROUGH IDLE when Warm STILL :(
    Dec 2011
    IL
    Sure did. I bought bosch at first but then took them back for iridium AC Delco's. It said misfire on cylinder 2
  4. #4 Re: ROUGH IDLE when Warm STILL :(
    GTP Level Member
    Oct 2011
    Raleigh, NC
    have you cleaned your iac ?
    1997 Red GTP 182000 miles stock
  5. #5 Re: ROUGH IDLE when Warm STILL :(
    Dec 2011
    IL
    replaced it.
  6. #6 Re: ROUGH IDLE when Warm STILL :(
    I wonder if when the ICM gets hot, its start to turn faulty and give you the misfires.
    Got anyone you know that you can try and swap them for a bit to see if that might be the problem.
  7. #7 Re: ROUGH IDLE when Warm STILL :(
    Dec 2011
    IL
    Hmmm, if you could point me in the right direction of doing that, I'm sure I could do it myself. If not, I will keep trying until i get it
  8. #8 Re: ROUGH IDLE when Warm STILL :(
    The ICM is under the coil packs. Its what the coil packs bolt too. That can be faulty and a cause misfire.
  9. #9 Re: ROUGH IDLE when Warm STILL :(
    Dec 2011
    IL
    I wonder how much that costs? Have an hour before autozone closes
  10. #10 Re: ROUGH IDLE when Warm STILL :(
    They are kinda pricey, that kinda why I said to see if you got anyone you know with the same car and see if you could swap them real quick and see if the issue goes away.
    I cant tell you for sure its the problem, so I dont want you to buy something you dont need.
  11. #11 Re: ROUGH IDLE when Warm STILL :(
    Yoga city
    i gots one if you need it with a couple coils on it
  12. #12 Re: ROUGH IDLE when Warm STILL :(
    Dec 2011
    Madison WI
    I had the same issue with my 99 Grand Prix GT. Cylinder 5 was misfiring when the engine was warmed up and I ended up ordering a $76 ICM from Rock Auto and have not had an issue since. If only Cylinder 2 is misfiring, swap the coil from a working set of cylinders and see if the issue moves with the coil pack, if not; you are looking at a ICM. I also noticed when replacing my ICM the aluminum plate that it mounts too was a bit corroded from coolant. I wire brused the aluminum down so it made good contact with the ICM. Think of it like a cooling heat sink for the ICM.
  1. rough idle when warm
    By rah575554eg in forum General Tech Discussion
    Last Post: 08-07-2011, 08:46 AM
  2. Surging idle when warm
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2010, 10:21 AM
  3. Warm engine won't idle.
    By Jaybird in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2010, 04:51 AM
  4. Rough on warm start
    By hacket in forum General Tech Discussion
    Last Post: 03-22-2009, 12:01 PM
  5. Rough when cold; smooth when warm...???
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 07:34 PM
