Thread: No Aluminum LIM Gasket for N/A Engine?
Results 1 to 20 of 20
  1. #1 No Aluminum LIM Gasket for N/A Engine?
    GTP Level Member SuperSport's Avatar
    Michigan
    Is it true that the aluminum LIM gasket is available only for the L67 or L32 engine? Ive heard that the only LIM gasket available for the L36 is plastic.
    If its only plastic I might as well not even bother replacing the LIM gasket, its just gonna leak again...
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  2. #2 Re: No Aluminum LIM Gasket for N/A Engine?
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    it wont if you take the plastic eating dexcool out and replace it with conventional green......
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  3. #3 Re: No Aluminum LIM Gasket for N/A Engine?
    Nov 2008
    Fremont Nebraska
    everything ive read says its the dexcool.
    and those problems you stated with the conventional green are complete BS
  4. #4 Re: No Aluminum LIM Gasket for N/A Engine?
    Michigan
    Anybody else?
    Is their an aluminum LIM gasket for the L36? Yes or No?
  5. #5 Re: No Aluminum LIM Gasket for N/A Engine?
    all the LIM gaskets are the same. just get the aluminum ones from an l32/l26.
  6. #6 Re: No Aluminum LIM Gasket for N/A Engine?
    Jan 1970
    Maquoketa, Iowa
    X2, the upper intake gaskets would be different.
  7. #7 Re: No Aluminum LIM Gasket for N/A Engine?
    Michigan
    Thanks guys!
  8. #8 Re: No Aluminum LIM Gasket for N/A Engine?
    Oct 2008
    Northern Illinois
    Yep, they're the same.
    And dexcool is the worst thing you could ever put in your engine.
  9. #9 Re: No Aluminum LIM Gasket for N/A Engine?
    Michigan
    Quote Originally Posted by BwolfGT View Post
    I just dont know how GM uses dexcool across the board, like all the ls engines, etc. but its only a problem with the 3.1, 3.4 and 3.8 engines that ive seen.
    Ill keep using dexcool, but changing it out every year, instead of the recommended 5. People leave the dexcool in and never change it, then a leak in a gasket comes along, then it sludges the whole cooling system.
  10. #10 Re: No Aluminum LIM Gasket for N/A Engine?
    GM had bad head gaskets on the 3100's. People also mix the green and dex and it sludges and people blame the dex...
  11. #11 Re: No Aluminum LIM Gasket for N/A Engine?
    Michigan
    Quote Originally Posted by matt5112
    Yep. Im keeping my dex.
  12. #12 Re: No Aluminum LIM Gasket for N/A Engine?
    dexcool only sludges when it gets oxidized (air in the system).
  13. #13 Re: No Aluminum LIM Gasket for N/A Engine?
    Oct 2008
    Northern Illinois
    It'll dig into your heads too.
  14. #14 Re: No Aluminum LIM Gasket for N/A Engine?
    prove it.
  15. #15 Re: No Aluminum LIM Gasket for N/A Engine?
    FWIW I've seen Series ! motors that only came with green coolant with the same gasket issues. Same LIM pitting as well. The issue with the gasket is mostly a gasket design, this is why GM now offers aluminum gaskets for both the 3100 and 3800 motors.
    As well the 5.3L in my pickup suffers from the same gasket issue. The truck guys don't blame Dex like the car folks do. They see it as a poor gasket design. Once you swap the gasket to aluminum, it's not an issue as long as you don't air up your cooling system too frequently
  16. #16 Re: No Aluminum LIM Gasket for N/A Engine?
    Oct 2008
    Northern Illinois
    prove it.
    Ok. I'll take pictures of my old heads tomorrow if I have time.
  17. #17 Re: No Aluminum LIM Gasket for N/A Engine?
    Jersey
    there is nothing wrong with dex. I still use it
    16' wrx sti- stock
  18. #18 Re: No Aluminum LIM Gasket for N/A Engine?
    Oct 2008
    Northern Illinois
    Quote Originally Posted by 99prixgt View Post
    Yeah, some people do ok with it. I've seen people like you run it to 200K with no issues, and I've also seen it destroy engines. A friend of mine explained the whole thing to me REALLY well once, but I can't remember what he said lol.
  19. #19 Re: No Aluminum LIM Gasket for N/A Engine?
  20. #20 Re: No Aluminum LIM Gasket for N/A Engine?
    Oct 2008
    Northern Illinois
    the dexcool did not eat away at your heads.
    Never said anything about eating them away. Clogging them, yes.
  1. Engine Gasket Kit?
    By projectGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2009, 07:40 PM
  2. engine not firing after UIM and LIM gasket replacement
    By Dericm02 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-03-2009, 02:30 AM
  3. Aluminum oil pan
    By quiksilvergt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-26-2008, 12:45 PM
