Thread: New member trying to remove the fuel injectors
Results 1 to 8 of 8
  1. #1 New member trying to remove the fuel injectors
    Apr 2009
    Ohio
    Hello, I have a '00 GT with a 3.8, and I'm in the process of removing the intake. I'm at the fuel rails and I have everything disconnected, but I can't seem to get the fuel injectors to come out. I can get them rotate, but they wont come out. Can someone give me a little insight and tell me what I'm missing? Thanks!!
  2. #2 Re: New member trying to remove the fuel injectors
    GTX Level Member cerick08GP's Avatar
    Well, I’ll assume they are similar to my 08. I hope someone can confirm quick.
    They all come out together with the fuel rail. Just pull straight up from the middle, but of course there are 4 nuts holding the fuel rail down that need to be removed first.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  3. #3 Re: New member trying to remove the fuel injectors
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    they should pop out by pulling on them, of course without damaging them. its the o rings doing there job, thats y its being difficult. just tug on them, if anything u will need new o rings. did mine like that when i replaced the lim gaskets.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  4. #4 Re: New member trying to remove the fuel injectors
  5. #5 Re: New member trying to remove the fuel injectors
    Apr 2009
    Ohio
    Well I got em out. They didn't want to come out easy though. Thanks for the help!
  6. #6 Re: New member trying to remove the fuel injectors
    A tip for this is to spray a little pb blaster at the o-rings to help them to soften and come out.
  7. #7 Re: New member trying to remove the fuel injectors
    Nov 2010
    il
    ok, stupid question here but how do you get the little clips off the plug to the injectors without breaking them? I'm pretty mech inclined here but cant seem to figure out what exactly to do to not break this plastic pos taking it apart! I'm used to wrenching on my 69 gto and this new stuff with all the wiring looks like a birds nest to me. ive got all the plugs apart except the ones going to the injectors. I know I can get them apart but I figured before I break something for no reason I'd ask ahead of time as to what the "trick" is so to speak. It was beer time anyway!!
  8. #8 Re: New member trying to remove the fuel injectors
    Nov 2010
    il
    oops! nevermind!! I was trying to remove the clips instead of pushing them towards the supercharger for lack of a better term here. Maybe this will help someone else out though... Bonehead move here!!!
  1. Fuel Injectors Leaking?
    By skidsteer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-05-2009, 10:46 AM
